03-03-2010, 11:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | 5130 flash ok but still problem..need help (answered) set was not powering on...when press power button it only vibrate a little and nothing else,no light no power.. i tried to flash with usb cable (ver 7.95) now when i try to power on it ,,,it shows nokia logo on screen for 3,4 seconds then lcd became white and then phone turned off...i tried with 7 pin fbus cable but still same condition...i tried the original firmware version (7.91)(found by product code).also flashed with ver 6.94 but no luck. after flash completed with hwk,jaf,mxkey factory setting failed. here is scan log of mxkey.... ------------------------------ Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0B300008C5978C563641DC7FBA75C0E0EC1BA4B0 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35826803264083 Original Product code: 0586705 Bluetooth ID: A87E33D44F1B Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35826803264083-2 Product Code: 0586705 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3582680xxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF ------------------ please tell me how to bring it to life.......... |
The Following User Says Thank You to quasim0438 For This Useful Post: |
03-03-2010, 12:26 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | quasim0438 open your mx-key nokia service tool. and connect you phone by modified f-bus cable,phone must be in test or local mode. than go,------- service>phone test>various>bb5 certificate validation see whats your hwc and ccc data condition. and post here log----- |
The Following User Says Thank You to shahinahmed007 For This Useful Post: |
03-03-2010, 12:55 | #5 (permalink) |
Member: 237155 Status: Offline Thanks Meter: 415 | NK module version: 1.09 NK applet version: 00.20 NK module ready. Please "Scan" or "BUS check" before any operation ... RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0B300008C5978C563641DC7FBA75C0E0EC1BA4B0 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Reading RAP NPC (0x168 bytes) Original Product Code: 0586705 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0586705 CCC seems to be valid Reading RAP HWC (0xD4 bytes) Product Code: 0586705 HWC seems to be valid |
03-03-2010, 13:43 | #6 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | quasim0438 your all info ok. so first change batery. try normal mode by cable and see whats the result if not ok than sure its hw fault |
03-08-2010, 02:41 | #9 (permalink) |
Freak Poster Join Date: Mar 2006 Location: 102c Trần Hưng
Member: 243559 Status: Offline Sonork: MACS Thanks Meter: 11 | 5130c fash log Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 14F6846F RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 10D000163F397F5654F78CA977075496D95D0A6C RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 10285742 [ADL] Verifying communication to device OK. Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.797 s CMT NOR area [000006C0-0001FFFF] erased in 0.843 s CMT NOR area [00040000-000BFFFF] erased in 3.203 s CMT NOR area [000C0000-0013FFFF] erased in 3.187 s CMT NOR area [00140000-0137FFFF] erased in 1 min 39.625 s CMT NOR area [01380000-0151FFFF] erased in 9.906 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Error while programming [00] at 0x014F0400, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 2 min 45.437 s |
03-08-2010, 02:48 | #10 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | try with version 7.something then post here 100% tested by me same problem on you but solve with 7.somethin version |
03-08-2010, 05:40 | #12 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
flash with jaf also use modi5 cable up lord letst ver. testing me many time and you can also it | |
04-15-2010, 20:22 | #13 (permalink) |
Crazy Poster Join Date: Oct 2007 Location: Ukraine
Member: 607412 Status: Offline Thanks Meter: 8 | I have this same problem) solution is wery simply - just switch-off camera (try turn on phone without camera) then try replace it. |
The Following User Says Thank You to Remservis For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
