Old 03-05-2010, 17:52   #1 (permalink)
Member: 625563
Sonork: Niceguy
Thanks Meter: 40
5130 flashing problem
i have a 5130 i click on bus check and give me this error
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 17D00116BBC87D56ECBE2A76A62BEC9F70838C6F
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35422303906734
Original Product code: 0571593
Bluetooth ID: 0025CF26ADAC
Phone not responding !
what can i do i flash this set on jaf flashing is complete but after flashing processing not don and phone is on but only show nokia logo what can i do please help me.
Old 03-05-2010, 18:03   #2 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
check ur cable use good working fbus cable
Old 03-05-2010, 18:08   #3 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
just flash latest version and flash with Nokia USB ROM dead usb flash chose Rm 495
Selet MCU PPm CNT Files And Click Flash
Old 03-06-2010, 05:58   #4 (permalink)
Member: 625563
Sonork: Niceguy
Thanks Meter: 40
on usb flashing start but after mcu flash complete show this error
Writing PM...
Field: 1, Record: 0, Len: 12 -> Error writing PM file!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Changing flashing settings...
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.mcusw
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.ppm_mh
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.image_mh_red
Detected P-KEY: 90009699
P-key nokia module version 01.02
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Not found!!!
PRESS POWER ON NOW!
PRESS POWER ON NOW!
Searching for phone...Found
Reading SW version...Error reading rap ver!
PRESS POWER ON NOW!
Sending RAW loader...
Using 06.02.002
Elf2flash 07.40.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ...................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 2167, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.mcusw...
Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.ppm_mh...
Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-495\rm495__06.93.image_mh_red...
Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
DCT4/BB5 counter: 43
Done!
now what can i do sir please help me.
5130 ,2700,6303 flashing problem rishi1985 HWK 24 09-15-2011 09:59
5130 flash ok but still problem..need help (answered) quasim0438 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 11-20-2010 06:35
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
help 5130 flash problem ??? vbrdll Cyclonebox 1 03-04-2010 07:09
5130 flashing problem masterprinters Nokia Base Band 5 ( BB-5 ) 0 02-13-2010 10:07
Page generated in 0.20014 seconds with 9 queries
