02-11-2010, 12:57 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | <<<<<<<<5130 give idea>>>>>>>>> after 3 min mobile off imei okay |
The Following 2 Users Say Thank You to delux_gsm For This Useful Post: |
02-11-2010, 13:26 | #5 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | Powering the phone... Reading... MCU SW version: V 07.91 29-10-09 RM-495 (c) Nokia HW version: 2000 PCI version: RFIC version: 06540601 DSP version: ICPR72_09w33 LCD version: SEIKO PPM version: V 07.91 29-10-09 RM-495 (c) Nokia AA BT MCM version: 2222-302 Retu version: 16 Tahvo version: 22 Content Pack version: Content: aa_red V 07.91 29-10-09 RM-495 (c) Nokia Production serial number: IIO613364 Product code: 0576616 Module code: 0204024 Basic production code: 0567772 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 355232039165188 IMEI spare to net: 3A 55 32 02 93 61 15 08 IMEI SV to net: 33 55 32 02 93 61 15 48 F7 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-495.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0576616 Searching for JAF saved location of ini... Checking path: D:\Program Files\Nokia\Phoenix\Products\RM-495\ Searching for default location of ini... |
The Following User Says Thank You to delux_gsm For This Useful Post: |
02-11-2010, 13:35 | #8 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: UNITED ARAB EMIRATES Age: 41
Member: 760274 Status: Offline Thanks Meter: 146 | Quote:
dear if you have mx key do bus check then post bus check log here first... | |
02-14-2010, 14:50 | #9 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | here Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2380000420C77D5633CE8ECF00D7F0895EFC6DA3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35523203916518 Original Product code: 0576616 Bluetooth ID: 0025D035692E Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35523203916518-8 Product Code: 0576616 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed "RM-495" folder created. Imei net: 355232039165188 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-14-2010, 14:59 | #10 (permalink) |
Major Poster Join Date: Nov 2008 Location: buinesaires
Member: 902108 Status: Offline Sonork: jhon_gate Thanks Meter: 11 | SIMLOCK invalid! SUPERDONGLE_KEY invalid!>>>> this u problem,,, u must repair <SIMLOCK invalid!> and <SUPERDONGLE_KEY invalid> - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed and mx-key suport repair sd u phone |
02-14-2010, 15:06 | #11 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | SUPERDONGLE_KEY invalid! that meens phone have damge SD data.U can repair this section with mxkey.Go to Imei and security select rpl section then press Super SD.It will repair ur SD key.Do it and post result. |
02-14-2010, 15:26 | #12 (permalink) | |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | here Quote:
Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.91 29-10-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F ERROR: Missing SD BLOCK or PM corrupted ! | |
02-14-2010, 15:29 | #13 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
02-14-2010, 15:45 | #15 (permalink) | |
No Life Poster Join Date: May 2007 Location: Badui My home
Member: 508048 Status: Offline Thanks Meter: 123 | Quote:
get result after that,.. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35524603005804-4 Product Code: 0578115 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! what can I do brother... | |
I Give 200 Usd To Who Gives Me Nokia6260 Flash File | xavien | Wanted Products | 35 | 01-24-2010 17:24 |
Give me 5 numbers and i give u 20,000 Euros,NOT FAKE! | mp3hot | Off Topic Zone | 63 | 12-02-2005 18:38 |
give me t720 code i'll give you any panasonic service manual | Platijet | Phone Unlocking Codes & Maps | 0 | 11-04-2003 19:03 |
