Old 02-06-2010, 08:23   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Unhappy 5130 pa sl3 i rty repair but cannot gat success
Product: V 07.90 23-09-09 RM-495 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 9.812 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-495_359336038595703_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
missing NPC data.
Certificate programmed successfully !
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 15F00102BEED8C56DFC990B032D1E11A20490EFE
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD ] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35933603859570
Original Product code: 0571957
Bluetooth ID: EC9B5BDAE4F7
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Imei plain: 35933603859570-3
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
"RM-495" folder created.
SIMLOCK_DATA corrupted!
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
warning: SD authorized but verify failed !
Completed in 13.906 s
Version Info:
MCU SW version: V 07.90 23-09-09 RM-495 (c) Nokia
RFIC version: 06540601
DSP version: ICPR72_09w33
LCD version: SEIKO
PPM version: V 07.90 23-09-09 RM-495 (c) Nokia EG
BT MCM version: 2222-302
Retu version: 16
Tahvo version: 22
Content Pack version: Content: eg_red V 07.90 23-09-09 RM-495 (c) Nokia
Product Info:
Production serial number: 0
Long production SN: 0
Serial Numbers:
IMEI plain: 359336038595703
IMEI spare to net: 3A 95 33 06 83 95 75
IMEI SV to net: 33 95 33 06 83 95 75 40 F4
Other Info:
Model : Nokia 5130c-2 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900
BSI: 5.1 KOhm
LCD version: SEIKO
Retu version: 16
Tahvo version: 22
Product Info:
Serial Numbers:
Other Info:
BSI: 5.1 KOhm
Socket error (10060): Connection timed out
Reading RF settings from phone ...OK, finished. 0 Records found.
Reading BB settings from phone ...OK, finished. 0 Records found.
Reading Product settings from phone ...OK, finished.
Reading Display settings from phone ...failed.
Reading Bluetooth ID settings from phone ...OK, finished.
Reading Wlan settings from phone ...OK, finished.
Writing Product settings to phone ...OK, finished.
Writing Display settings to phone ...OK, finished.
Writing Bluetooth ID settings to phone ...OK, finished.
Completed in 8.422 s
ANY CAN SOLUTION THIS HOPE WE CAN UDD THIS TEAM
WITH BEST REGARDS:
LILONG LEE
The Following User Says Thank You to lilong_lee For This Useful Post:
Old 02-06-2010, 10:12   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
sir manoli how to solve this problem
Old 03-25-2010, 17:31   #3 (permalink)
Member: 1237338
Thanks Meter: 3
hi pal, maybe you should try to install the last version of mxkey, when you repair superdongle itself repair simlock too, otherwise the problem with "Reading Display settings from phone ...failed." i think that the only solution is write the RF/BB Tuning file for another phone (same model), i have the same problem with rm-356 nokia 5800.
Old 03-25-2010, 18:42   #4 (permalink)
zolla's Avatar
Member: 175544
Thanks Meter: 198
if SIMLOCK_TESTis failed! dont loose ur time cos phone is sl3
Nokia 5130 SP data possible to repair[SL3 PHONE UNSUPPORTED YET] gsm5378 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-20-2010 09:38
can mx key repaire camera on standby in 5130 : i tried many sets but no success soft sanjayvikas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-01-2010 06:37
MX KEY NEW UPDATE BB5 SIMLOCK DATA/KEY PA SL3 write diljan_07 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 01-29-2010 02:37
Se repaired but cannot flash ENG. ADETUNJI Cruiser Suite 0 10-08-2008 12:47
3660 SUCCESS IN FLASHING but cannot power on bugztronic WD2 & APE (Symbian Phones) 10 09-10-2008 02:59
Page generated in 0.17046 seconds with 9 queries
