Old 12-03-2010, 08:49   #1 (permalink)
lukylike_102's Avatar
Member: 224601
Thanks Meter: 24
5130 restart problem (ANSWERED)
set flash ok but when i play vedio song set restart here is log i flash usb and fbus but same problem
ersion from phone: 07.97
Version from file: 07.97
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 10B00110AE0301568B7EC727506CA6BD95960623
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Flash Imei: 35378604321567
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\Program Files\mobileEx\3.4\data\backup\BB5_35378604321567_ BACK.rpl"
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 1 min 48.328 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 1 min 56.734 s
Processing PPM file: rm495__07.97.ppm_t
[BB5,BB5 ALGORITHM] size: 7.43 MB
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF]
erased in 43.187 s
Programming completed in 45.594 s
Processing CNT file: rm495__07.97.image_t_au_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB
Converting UCP blocks to 128 K.
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF]
CMT NOR area [02160000-03FBFFFF]
erased in 3 min 23.359 s
Programming completed in 1 min 3.094 s
Total time for flashing process(boot+erase+write) was 9 min 48.516 s
Flashing completed in 11 min 53.906 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35378604321567-9
Product Code: 0576616
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353786043215679
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.484 s
UFS2 SarasSoft disconnected.
The Following User Says Thank You to lukylike_102 For This Useful Post:
Old 12-03-2010, 11:26   #2 (permalink)
Member: 224601
Thanks Meter: 24
wait your reply all brothers
Old 12-03-2010, 17:21   #3 (permalink)
Cheater -Don't Deal with him-
Member: 1179761
Sonork: 100.1602000
Thanks Meter: 1,834
i think hardware problem
check hardware
Old 12-04-2010, 02:53   #4 (permalink)
Member: 36600
Thanks Meter: 2
reheat upp and uem brother
Old 12-04-2010, 05:57   #5 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
i thinks hardware .serch forum already post solution .
Old 12-04-2010, 20:22   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
many time discussed, for sure it is hardware problem.
check for flash chip.
Old 12-05-2010, 11:46   #7 (permalink)
Member: 709126
Thanks Meter: 3
rehot upp and uem then solve
Old 12-05-2010, 16:20   #8 (permalink)
Member: 269126
Sonork: 100.1616382
Thanks Meter: 370
change bluetooth ic or remove if not then change mmc ic its should 100 %%%% ok i have tested if still not then change handsfree ic............
Old 12-06-2010, 06:51   #9 (permalink)
Member: 629860
Thanks Meter: 53
check it lol
http://forum.gsmhosting.com/vbb/f550...-here-1156896/
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.19415 seconds with 9 queries
