Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 09-21-2009, 09:45   #1 (permalink)
DIN231080's Avatar
Member: 523792
5130 restart when call any solution
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.93 20-05-09 RM-495 (c) Nokia
Imei plain: 35690803682***-*
Product Code: 0577793
VariantId: M
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei: 356908036824492
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
mobile work fine but restart when call please give solution rpl is ok
The Following User Says Thank You to DIN231080 For This Useful Post:
Old 09-21-2009, 12:36   #2 (permalink)
Member: 205475
yes me too what the problem many pieces of this mobile same problem so what the solution's
Old 09-21-2009, 14:40   #3 (permalink)
mr. uem's Avatar
Member: 1035137
just try to full factory default first with tools supporting it.
Old 09-21-2009, 18:50   #4 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
VariantId: M
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Counter: 0/3, 0/10
no bro
ur data is good
about simlock wrong info its just bug in this version with protected models info(will fx in next update)
ur SD state is good 2
try 2 go 2 service,phone tests,various,watch dog test (WD)
if its fine ,may be u have HW problem
wbr
The Following User Says Thank You to mohA™ For This Useful Post:
Old 09-22-2009, 03:57   #5 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
let me say the hardware chances too
restart when calling and TURN OFF when calling , these two fault i found in this model
turn off when call can be diogonised by measuring current consumption of the set (mostly the rf PA consumes much)
but restart case is different .....
unstable oscillation may be a chance , we can change clock crystal and vco blindly
before doing that you should clean&dry the pcb very well
any way try these and post
regards,
NEIL
The Following User Says Thank You to neilthirumuttam For This Useful Post:
Old 03-03-2010, 06:47   #6 (permalink)
Member: 388272
mobile work fine but restart when call please give solution i change pa same
Old 03-03-2010, 07:25   #7 (permalink)
singhdeep's Avatar
Member: 395477
Sonork: 100.1602978
no need to change pa
just replace ear speaker if not work check component near speaker
i solved this problam one month ago
Old 03-03-2010, 08:03   #8 (permalink)
p4padne's Avatar
Member: 870153
Sonork: 100.1594619
full flash with latest ver. write good pm
other wise, check hardware
The Following User Says Thank You to p4padne For This Useful Post:
Old 03-03-2010, 08:13   #9 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
yes, try this solution am tested many times,
u can check ur fone without speaker
if that time phone is ok
change ear speaker.
Old 03-03-2010, 09:22   #10 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
yes right change speaker or change the front steel frame of display...im tested many times...
Old 03-03-2010, 09:28   #11 (permalink)
romeoluv56's Avatar
Member: 1170910
same problem to me also any help ?
The Following User Says Thank You to romeoluv56 For This Useful Post:
Old 03-03-2010, 09:30   #12 (permalink)
malektalha's Avatar
Member: 1062869
riplce originol speker ok tested
The Following User Says Thank You to malektalha For This Useful Post:
Old 03-03-2010, 09:31   #13 (permalink)
Sonork: 100.1592050
Arrow
VariantId: M
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Counter: 0/3, 0/10
upload ur rpl backup here or send me via pm
Old 03-03-2010, 09:33   #14 (permalink)
romeoluv56's Avatar
Member: 1170910
thanks i'll try and post here
Old 03-10-2010, 12:37   #15 (permalink)
Member: 350316
5130 restart when play music player on 15 minute alamgir80 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 01-16-2010 10:07
5130 restart when make or recieve call ? .:RoMeO:. Nokia Hardware & Hardware-Repair Area 1 11-01-2009 12:50
5130 Restart When Call is MADE Amir-SkillZ Nokia Base Band 5 ( BB-5 ) 6 10-16-2009 00:58
BE4 restarting when call in progress !! makona Alcatel & TCL Old Models 11 08-22-2001 07:11
Page generated in 0.51837 seconds with 11 queries
