Old 12-13-2011, 09:14   #1 (permalink)
Member: 772386
Thanks Meter: 157
5130 simlock (ANSWERED)
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35604003696174-2
Product code: 0571584
Battery voltage: 4368 mV, current: 63 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
how i repair this set
Old 12-13-2011, 09:16   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
do you have this unit backup? press restore imei.
no backup? buy factory rpl.
been discussed maaaanny times
Old 12-13-2011, 11:47   #3 (permalink)
Member: 772386
Thanks Meter: 157
i have only pm backup, how i buy rpl? can u tell me in details
Old 12-13-2011, 14:09   #4 (permalink)
Member: 780195
Thanks Meter: 24
if you have pm backup then check 120 section and write that your problem will solved
Old 12-13-2011, 14:27   #5 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
this is 5130 log
Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 05E0000B1DBD465039A4BDC0096F1E65FB62E3B1
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung ] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35+++++++++++++
Original Product code: 0591479
Bluetooth ID: C8979FF77143
when i flash, no test mode, only RAP BACKUP
CAN I USE CERTIFICATE RESET-NPC,CCC,HWC????????
HOW I READ BACKUP SIMLOCK DATA???
IS THIS SAFE METHOD READ SIMLOCK DATA
PL. HELP
REGARDS
Old 12-13-2011, 17:09   #6 (permalink)
gkmobiles's Avatar
Member: 1222236
Sonork: 100.1619169
Thanks Meter: 288
Originally Posted by omkarvitekar View Post
this is 5130 log
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
PL. HELP
REGARDS
remove camera then try flash
Old 12-13-2011, 17:10   #7 (permalink)
gkmobiles's Avatar
Member: 1222236
Sonork: 100.1619169
Thanks Meter: 288
Language Pack:
- not available.
SIMLOCK invalid!
Old 12-14-2011, 10:28   #8 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 35
if you don't have a factory rpl , change MCU from other phone "5310".
"if you have a old 5310 u can get mcu from it and you convert your phone to sl2 "after backup rpl befor flash the phone to 5130"
Old 12-16-2011, 07:57   #9 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
i aslo tried with out camera & display
whats next
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
5130 V.61 bzegarac Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-20-2000 11:37
5130 5190 6190 MGG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-03-2000 20:36
SimLock Level 4 counter HitMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-12-1999 00:17
N6150 simlock open??? Tommy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-21-1999 09:31
Page generated in 0.20802 seconds with 9 queries
