10-11-2009, 20:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | 5130 strange problem Using device: UFS_USB V2.8 (c) SarasSoft 2007. Processing file: rm495__06.94.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.17 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 0890000F0E9D7D56BF0AA3012C04C3C61877D01D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.641 s CMT NOR area [000006C0-0001FFFF] erased in 0.062 s CMT NOR area [00040000-000BFFFF] erased in 2.484 s CMT NOR area [000C0000-0013FFFF] erased in 0.141 s CMT NOR area [00140000-0137FFFF] erased in 1 min 17.281 s CMT NOR area [01380000-0151FFFF] erased in 8.250 s Flash programming ... Valid PAPUB key found CMT PAPUBKEYS, RAP Certificate 164 v.1 written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x01060400, Result: 0010 Flashing terminated with error(s) in 3 min 58.657 s RX Buffer: C7012D0103CD000010000000F172 I want to know What is this error indicate. And is there any solution to make this phone alive. |
The Following User Says Thank You to Riteshgpt60 For This Useful Post: |
10-11-2009, 20:40 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | Flash yr phone other device 100% tested like Jaf Hwk mt ect. i face same sitituion with nokia 5220 i totly flash it with jaf but not power up then i use hwk after that i again with jaf its work ok |
10-11-2009, 21:27 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, there are two possibility for you case: 1st reason is flash loader, and the second is bad cable. please try with usb flashing. make sure you are using the latest version for your 5130. If the problem still the same, fix your flash folder (re-install mxkey) br |
10-12-2009, 02:33 | #5 (permalink) | |
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
Processing file: rm495__06.94.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.17 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Phone must be switched off. Press phone's POWER button or connect a CHARGER now ! warning: Some new phones consume more power, please connect cable to USB host instead of USB hub. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic-bf2166 RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM1 ID: 00000296 RAP EM2 ID: 00000B22 RAP PUBLIC ID: 0890000F0E9D7D56BF0AA3012C04C3C61877D01D RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, UPDAPP: 0x49EC0 bytes [ADL] Update Server code succesfully sent to phone [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x58400 bytes [ADL] Update Server code succesfully sent to phone [ADL] Pooling for ADL device [ADL] Timeout, no device not found. Flashing terminated with error(s) in 35.125 s RX Buffer: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000 i used 7 pin gpg cable and also i try with 3.2 ver5, when not success with ver5.2 | |
10-12-2009, 02:42 | #6 (permalink) | |
http://i34.tinypic.com/2mciwba.jpg | |
10-12-2009, 03:04 | #7 (permalink) |
Insane Poster Join Date: May 2006 Location: .:SEGO MEGONO:.
Member: 272532 Status: Offline Thanks Meter: 8 | use latest version v3.2 revision 5.3, Public-Release |
10-16-2009, 16:00 | #8 (permalink) | |
Please Help!!!!!! Phone comes in contact service but dead now | |
10-27-2009, 12:31 | #9 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: chttagong
Member: 571857 Status: Offline Thanks Meter: 20 | Quote:
hello dear try other device | |
10-27-2009, 18:28 | #12 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
11-01-2009, 01:42 | #13 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Central JAVA
Member: 616091 Status: Offline Thanks Meter: 27 | may i know how to fix flashloader. how about klik update loader..? i got some problem on some bb5. but fortunatly if i klik check 2nd or 3rd after klik restart. its become ok.. |
07-15-2010, 04:42 | #15 (permalink) |
Freak Poster Join Date: Sep 2006 Location: ludhiana,punjab
Member: 348478 Status: Offline Thanks Meter: 62 | after usb flash in mxkey Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm495__07.95.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.20 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 451404D RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] RAP EM0 ID: 00000296 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 1050020D6FA27D56582B52E744D02B067607DA1C RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Polling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 54.219 s |
5130 strange problem | google_uk | Nokia Base Band 5 ( BB-5 ) | 7 | 05-17-2011 16:49 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
5130 strange problem plz help | rana_jee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-01-2010 13:29 |
5130 strange problem | .::Indrojith::. | Nokia Hardware & Hardware Repair | 6 | 08-24-2009 08:00 |
