5130c-2 Contact service-when can Mxkey solve this 5130c-2 Contact service-when can Mxkey solve this refer to this Quote:
how about this case is it need Nokia RPL Service? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 27100208A33A7D563B53EA1911466304FF55265F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35417903875511 Original Product code: 0571958 Bluetooth ID: 0025485D5E8C Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35417903875511-6 Product Code: 0571584 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed "RM-495" folder created. SIMLOCK_DATA corrupted! Version Info: MCU SW version: V 06.94 21-07-09 RM-495 (c) Nokia HW version: 1000 RFIC version: 06540601 DSP version: ICPR72_09w04 LCD version: SEIKO PPM version: V 06.94 21-07-09 RM-495 (c) Nokia AA BT MCM version: 2222-143C Retu version: 16 Tahvo version: 22 Content Pack version: Content: aa_blu V 06.94 21-07-09 RM-495 (c) Nokia Product Info: Production serial number: HEC345703 Product code: 0571584 Module code: 0204024 Basic production code: 0567773 Long production SN: 0 Serial Numbers: IMEI plain: 354179038755116 IMEI spare to net: 3A 45 71 09 83 57 15 01 IMEI SV to net: 33 45 71 09 83 57 15 41 F2 Other Info: Model : Nokia 5130c-2 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900 BSI: 4.1 KOhm SIMLOCK_DATA corrupted! and after do all this, it became different After Repair SD Supper SD Auth PM Auth Write PM Repair Simlock :D Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 27100208A33A7D563B53EA1911466304FF55265F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35417903875511 Original Product code: 0571958 Bluetooth ID: 0025485D5E8C Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35417903875511-6 Product Code: 0571584 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! thank in advance |
Its possible i have its solution |
So many ppls are already waiting for this update dear...wait n watch.. Br |
I don't know I do it wrongly or what? and also don't know that did it write or erase before because this phone have repair by other shop already and I try follow the above but still the same contact service thanks |
no solution without orignal rpl backup or new rpl |
nokia 2610b ufs flashing no network plz help me |
write pm ................................. |
1 Attachment(s) Quote:
This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! can u do this. we will appre.. ur work. solution pl... |
ATM, you can only solve this with backup or buy new RPL. |
