Old 03-25-2010, 07:56   #1 (permalink)
Member: 578236
Thanks Meter: 31
5130c-2 Contact service-when can Mxkey solve this
refer to this
Originally Posted by tanveeranjum View Post
Solution / Information ::.. about SL3 Contact Service
Phone Type: RM-495 (Nokia 5130c-2)
SW Version:
V 05.80 18-12-08 RM-495 (c) Nokia
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353223034396342
Version:
SIMLOCK SERVER
Provider: Nokia Test, Country:
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=
FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
how u can i repair this error ?
Just Do normal SX4 than write PM1 and PM309.
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Version:
SIMLOCK SERVER
Finland
Counter: 0/3, 0/10
CONFIG_DATA:
2440700000000000
PROFILE_BITS:
0000000000000000
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
FFFFFF
Just Do normal SX4 than write PM1 and PM309. ( don't care about Simlock invalid as all BLOCK are open SL data not corrupted)
SW Version:
Imei plain:
35322303439634-2
Product Code:
0577793
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed
SL data Corrupted
How can i repair mobile in this state?
No. u can repair this state of mobile as SL data is corrupted too. If u have Full RPL backup with Mxkey that yes . If no than Only Nokia RPL service is the solution.
SW Version:
Imei plain:
123456754321-?
Product Code:
0577793
Language Pack:
- not available.
imei invalid or plain
SIMLOCK invalid!
SUPERDONGLE_KEY seems to be invalid
mobile power off after 3 mins
SIMLOCK_TEST failed
SL data Corrupted
How can i solve this Error?
U can't repair the imei of the mobile for that u have to use Nokia RPL service.
but u can get this mobile out of contact service.
From Tanveer Anjum Khan Sub Eng Electronics
gsmtaunsa****
how about this case
is it need Nokia RPL Service?
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 27100208A33A7D563B53EA1911466304FF55265F
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35417903875511
Original Product code: 0571958
Bluetooth ID: 0025485D5E8C
SW Version: V 06.94 21-07-09 RM-495 (c) Nokia
Imei plain: 35417903875511-6
Product Code: 0571584
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
"RM-495" folder created.
SIMLOCK_DATA corrupted!
Version Info:
MCU SW version: V 06.94 21-07-09 RM-495 (c) Nokia
HW version: 1000
RFIC version: 06540601
DSP version: ICPR72_09w04
LCD version: SEIKO
PPM version: V 06.94 21-07-09 RM-495 (c) Nokia AA
BT MCM version: 2222-143C
Retu version: 16
Tahvo version: 22
Content Pack version: Content: aa_blu V 06.94 21-07-09 RM-495 (c) Nokia
Product Info:
Production serial number: HEC345703
Product code: 0571584
Module code: 0204024
Basic production code: 0567773
Long production SN: 0
Serial Numbers:
IMEI plain: 354179038755116
IMEI spare to net: 3A 45 71 09 83 57 15 01
IMEI SV to net: 33 45 71 09 83 57 15 41 F2
Other Info:
Model : Nokia 5130c-2 (Classic Phone)
CS type : GSM850/GSM900/GSM1800/GSM1900
BSI: 4.1 KOhm
and after do all this, it became different
After Repair SD
Supper SD Auth
PM Auth
Write PM
Repair Simlock
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
thank in advance
The Following User Says Thank You to Liheng For This Useful Post:
Old 03-25-2010, 08:02   #2 (permalink)
Member: 445967
Sonork: 100:1652029
Thanks Meter: 37
Its possible i have its solution
The Following User Says Thank You to shmily For This Useful Post:
Old 03-25-2010, 08:03   #3 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 473
So many ppls are already waiting for this update dear...wait n watch..
Old 03-25-2010, 08:08   #4 (permalink)
Member: 524163
Sonork: 1589680
Thanks Meter: 31
If u have, Please post here
The Following User Says Thank You to m_salunkhe2007 For This Useful Post:
Old 03-25-2010, 08:13   #5 (permalink)
Member: 578236
Thanks Meter: 31
I don't know I do it wrongly or what?
and also don't know that did it write or erase before
because this phone have repair by other shop already
and I try follow the above but still the same contact service
thanks
Old 03-25-2010, 08:56   #6 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,418
no solution without orignal rpl backup or new rpl
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 05-02-2010, 14:05   #7 (permalink)
Member: 1131870
Sonork: satheesh
nokia 2610b ufs flashing no network
plz help me
Old 06-15-2010, 13:18   #8 (permalink)
Member: 1325238
Sonork: thajtl
write pm .................................
Old 03-02-2011, 07:42   #9 (permalink)
Member: 824510
Sonork: 41000
Thanks Meter: 2
plz help me
simply change RX filter or direct
Old 03-02-2011, 09:28   #10 (permalink)
Temporary banned !!
Member: 374340
Sonork: 1604089
Thanks Meter: 26
wat r u talking Br,
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
can u do this. we will appre.. ur work.
solution pl...
Old 03-02-2011, 12:54   #11 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Thanks Meter: 679
ATM, you can only solve this with backup or buy new RPL.
The Following User Says Thank You to MOURAD™ For This Useful Post:
5130c-2 Contact Service....???? dil_PAKISTANI Nokia Base Band 5 ( BB-5 ) 5 04-11-2011 22:35
5130c-2 contact service jitmobile Nokia Base Band 5 ( BB-5 ) 12 08-29-2009 13:03
5130c-2 contact service fonERICKS Universalbox 3 07-04-2009 00:07
Page generated in 0.56205 seconds with 9 queries
