04-05-2010, 15:00 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: europe
Member: 387971 Status: Offline Thanks Meter: 64 | 5130c-2 xm flashing problem in mxkey definitly {solved} this is my first phone that I try to flash with mxkey. unlock work like charm (so far so good) phone is v6.65 and it is working and also it is locked, that is not matter since I need to change language on it. I select files and flashing was done ok ,but after flashing I get error phone not responding! Phone was dead since I wasnt able to switch it on. I check again did I select correct files and correct settings all looks good. Tryed to flash it again but same result. Since loader was 8.30.12.34536 I change it to 09.50.25.2. Tryed again and flashing was done again but same problem phone not responding! So I mark FAST FLASHING and after that I flash phone again with 09.50.25.2 loader but this time everything was OK.Phone is working. Now (for experiment) I change loader again from 09.50.25.2 to 8.30.12.34536 and flash it again with FAST FLASHING enabled.Result was OK. So conclusion, you should check FAST FLASHING in order to have working phone ,this is realy funny isnt it ? This info is correspond on 5130 that I have tested.Dont know will this resolve problem on some other models ,but it is funny! Till now I was perfering hwk for flashing,It looks like I will perfer it in the future also. br |
The Following 2 Users Say Thank You to MaxPayne For This Useful Post: |
04-22-2010, 19:00 | #3 (permalink) | |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | Quote:
bro can u try that with the latest version of mxkey too v1.8 /// please post result ... | |
The Following User Says Thank You to gsmsikar For This Useful Post: |
5130c-2 Contact service-when can Mxkey solve this | Liheng | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 03-02-2011 12:54 |
Solve Your Nokia Flashing Problem in 12 Hours | vdroy97 | Nokia Hardware & Hardware Repair | 4 | 10-08-2009 10:03 |
flashing problem in 5130c | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 07-21-2009 08:29 |
