Old 02-03-2010, 13:30   #1 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
5130c after repair sd erRor and sl crrupted
5130C AFTER REPAIR SD
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 128001036C1F7E56BDA8E7E28A68BA0F26AA7EC0
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35422303161209
Original Product code: 0572174
Bluetooth ID: 002548918BE1
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35422303161209-6
Product Code: 0576443
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
TimeStamp: 2009-10-09T12:22:40Z
SW Version: 06.94
Variant Version: 005
ProductProfile: RM495_0576443_06.94_005.spr
Simlock: 0576443_simlock.bin
SIMLOCK_DATA corrupted!
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post:
Old 02-03-2010, 13:37   #2 (permalink)
.::Skylinks::.'s Avatar
Member: 300354
Sonork: 100.1577485
Thanks Meter: 760
I also got 5130c on Same State But Still Same Problem... Did,t Solve with Mxkey
Old 02-03-2010, 13:53   #3 (permalink)
Gsm Benghazi's Avatar
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
BRO.
NOW THERE NOT ANY TOOL CAN REPAIRER SIMLOCK FOR SL-3 ( FOR EXAMPLE 5130C- N97 - N86.......etc)
only rpl from nokia server and use mx-key to write rpl to your phone
or you must wait may be in future
thanks forr all
Old 02-03-2010, 13:55   #4 (permalink)
Member: 20038
Thanks Meter: 19
hiehiehie u dont know what are u doing
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SW Version: 06.94
why u post if u don't know what sl 3 is?
Help,how to fix the phone with SD damaged and SL=0000000? Smartmio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-24-2010 11:26
5130c SECURITY_TEST failed! after Repair SD ZubairArain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-04-2010 18:30
6300 after repair sd error ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-03-2010 13:33
DOES MX-KEY SUPPORT NOKIA 5130c-2 RM-495 UNLOCKING AND SL REPARING?:)- sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 06-04-2009 19:03
Page generated in 0.18951 seconds with 9 queries
