02-06-2010, 14:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: chandigarh Age: 42
Member: 349524 Status: Offline Sonork: 100.1622727 Thanks Meter: 122 | 5130c contact service SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2010020B0E1459503EA428E193FC510E20607563 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 3593******* Original Product code: 0577793 Bluetooth ID: 0024045CE076 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 359****** Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! wat to do any hint's |
02-06-2010, 15:36 | #5 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | Quote:
Follow these 4 steps your phone will be OK. 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model | |
02-06-2010, 15:46 | #6 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
do u know that model is SL3 & it's not suppported | |
02-06-2010, 15:57 | #7 (permalink) |
Crazy Poster Join Date: Dec 2007 Location: Murtimant Complex, AHMEDABAD.
Member: 665431 Status: Offline Thanks Meter: 16 | 1. go to simlock an select Repair Simlock (tick on Make SIMLOCK RPL) and press [Repair Splock] now you get simlock valid 2. Go to IMEI Tab and do [Repair SD] 3. Go to Pm and do [SUPER SD Auth] and write PM i think it is enough for your phone Pls. post your resul for other member Thanks |
NOKIA 5130c CONTACT SERVICE | ami tomar | Nokia Base Band 5 ( BB-5 ) | 30 | 08-27-2011 21:03 |
Nokia 5130c contact service | UNLOCK PARK ® | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 11-25-2010 09:41 |
5130c Contact Service DONE by Cyclone | Code:L.A 22 | Cyclonebox | 16 | 09-12-2009 10:09 |
5130c contact service pls help this kind of problem | justine54 | Nokia Base Band 5 ( BB-5 ) | 11 | 09-06-2009 20:09 |
