03-09-2010, 16:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | 5130c contact service Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.12027, Date: 06-02-2010 Product: V 05.80 18-12-08 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...Connection timed out ERROR: could not connect to server! then when i try to write to do pm authorization it shows this SIMLOCK_DATA corrupted! superdongle invalid authorization might be failed to fix you need to restore the phones certificate(rpl) or rewrite pm 308:backup you want to continue? yes no here is the bus check of the phone i.e the information Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.12027, Date: 06-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 266001060F9D7D568EF9607C3D457DB9F86D9EC7 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35322303459405 Original Product code: 0572176 Bluetooth ID: 0025471A0871 Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35322303459405-2 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Reading Simlock info ... |
03-09-2010, 16:29 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | there are some SL3 phone list and not supported yet for UNLOCKING and SIMLOCK repair at moment Code: RAPUYAMA v1.11 PR_RTSA_BGA401/CSP - PA_SL3 Security 5630d (RM-431) 6720 Navigator (RM-491) 6700 Classic (RM-470) 6720 Classic(RM-424) 6730 Classic (RM-547) 6730 Classic (RM-566) 7020a (RM-497) E52 (RM-469) E55 (RM-482) E72 (RM-529) E72 (RM-530) RAPIDOYAWE 1.13E - PA_SL3 Security 5730s (RM-465) 5530 (RM-504) 5800d (RM-356) - v10.4.016 with HASH: 479C6DDE3942E12C429C1D6ADED80371 N97 (RM-505/506/507/555) RAPS_V3.03/3.02 - PA_SL3 Security 2700 Classic (RM-561) 2730 Classic (RM-578) 2730c-1b (RM-579) 3600 Slide (RM-352) v56.26 - v57.23 3720 Classic (RM-518) 5130 XpressMusic (RM-495) 5310 XpressMusic (RM-303) v58.58 - v59.42 6202 Classic 6300 (RM-217) v57.20 6303 Classic (RM-443) 6500 Slide (RM-240) v59.60 6500 Classic (RM-265) v59.45 7610 Slide (RM-354) v57.23 RAP3GS2 v4.1/4.11_C021 - PA_SL3 Security 3710a-1 (RM-509) 3710a-1b (RM-510) 3711a-1 (RM-511) RAPS2 v4.1/4.11 - PA_SL3 Security X3 (RM-540) X6 (RM-559) br, |
The Following User Says Thank You to Andra For This Useful Post: |
NOKIA 5130c CONTACT SERVICE | ami tomar | Nokia Base Band 5 ( BB-5 ) | 30 | 08-27-2011 21:03 |
Nokia 5130c contact service | UNLOCK PARK ® | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 11-25-2010 09:41 |
5130c Contact Service DONE by Cyclone | Code:L.A 22 | Cyclonebox | 16 | 09-12-2009 10:09 |
5130c contact service pls help this kind of problem | justine54 | Nokia Base Band 5 ( BB-5 ) | 11 | 09-06-2009 20:09 |
