02-22-2010, 10:17 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 5130c flashing problem Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm495__05.80.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.12 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2990011134407D56534C3F73983CBFB6C633858D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.797 s CMT NOR area [000006C0-0001FFFF] erased in 0.172 s CMT NOR area [00040000-000BFFFF] erased in 3.015 s CMT NOR area [000C0000-0013FFFF] erased in 0.219 s CMT NOR area [00140000-0137FFFF] erased in 55.235 s CMT NOR area [01380000-0151FFFF] erased in 3.922 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 2 min 35.125 s Processing file: rm495__05.80.ppm_el as PPM [BB5,BB5 ALGORITHM] size: 6.00 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2990011134407D56534C3F73983CBFB6C633858D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 38.328 s Flash programming ... Error while programming [00] at 0x01970000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 5 min 40.359 s RX Buffer: B372 |
02-22-2010, 19:34 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | uncheck MCU frimware then try reflash again this part continues your flashing before if still same error, recheck your cable and phone. br, |
02-23-2010, 12:02 | #6 (permalink) |
Member: 282510 Status: Offline Thanks Meter: 33 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm495__05.80.ppm_el as PPM [BB5,BB5 ALGORITHM] size: 6.00 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 2990011134407D56534C3F73983CBFB6C633858D ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 34.906 s Flash programming ... Error while programming [00] at 0x015B0000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 58.157 s RX Buffer: B372 without mcu, the phone is in dead condition now |
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
PLZ send me 5130c flash file only mt box tasted flash file usb flash | kashig | MT-BOX | 0 | 02-07-2010 18:53 |
flashing problem in 5130c | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 07-21-2009 08:29 |
5130c mmc problem | smsismail | Nokia Hardware & Hardware Repair | 0 | 07-01-2009 08:04 |
