01-30-2010, 08:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: from the dark past
Member: 744064 Status: Offline Thanks Meter: 99 | 5130c problem pls help... problem is if i power on nokia only then off after flashing same problem and heres the logs.... Using device: UFS_USB V2.8 (c) SarasSoft 2007.KulazGsm Library version: 1.0.0.11866, Date: 26-01-2010 Processing file: rm495__05.80.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.12 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13E00016B8DE7D56C04598B653DBF9FF385E1AC3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Storing certificate ...OK Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 1.734 s CMT NOR area [000006C0-0001FFFF] erased in 1.813 s CMT NOR area [00040000-000BFFFF] erased in 4.094 s CMT NOR area [000C0000-0013FFFF] erased in 0.360 s CMT NOR area [00140000-0137FFFF] erased in 1 min 20.469 s CMT NOR area [01380000-0151FFFF] erased in 8.593 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 3 min 49.046 s Processing file: rm495__05.80.ppm_el as PPM [BB5,BB5 ALGORITHM] size: 6.00 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13E00016B8DE7D56C04598B653DBF9FF385E1AC3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 29.985 s Flash programming ... Programming completed in 1 min 47.516 s Flashing completed in 8 min 50.500 s Phone not responding ! Total time to process is 9 min 37.625 s |
01-30-2010, 10:03 | #4 (permalink) |
Member: 744064 Status: Offline Thanks Meter: 99 | boss same problem i encounter when i flash with other version... Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11866, Date: 26-01-2010 Processing file: rm495__06.94.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.17 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13E00016B8DE7D56C04598B653DBF9FF385E1AC3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Storing certificate ...OK Total erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.828 s CMT NOR area [000006C0-0001FFFF] erased in 0.188 s CMT NOR area [00040000-000BFFFF] erased in 2.718 s CMT NOR area [000C0000-0013FFFF] erased in 0.250 s CMT NOR area [00140000-0137FFFF] erased in 1 min 20.454 s CMT NOR area [01380000-0151FFFF] erased in 8.188 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 3 min 1.125 s Processing file: rm495__06.94.ppm_mena_a as PPM [BB5,BB5 ALGORITHM] size: 6.24 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13E00016B8DE7D56C04598B653DBF9FF385E1AC3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Total erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 30.422 s Flash programming ... Programming completed in 1 min 0.657 s Flashing completed in 6 min 48.172 s Phone not responding ! Total time to process is 7 min 25.750 s |
01-31-2010, 22:09 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | go to : service - quickfix do -> "fix bb5 downgrade" of not help try with this : - backup RPL in NPC data only. - erase with safe flash. - flash with any version. - if can local mode,restore your NPC DATA backup br, |
Nokia 5130c expressmusic pls help me | brunosilva | Nokia Base Band 5 ( BB-5 ) | 1 | 09-03-2009 18:48 |
s25 problem pls help me | MaHuAk | x1x to x45/x50 | 0 | 06-11-2002 21:53 |
Big PROBLEM!!!...pls. HELP!... IMEI (656565) LOCKS(4 CLOSED) CAN IT BE REPAIRED? | Chryse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 02-08-2002 07:16 |
alcatel 3xx dead problem !!! pls help!!! | gsm-lord | Alcatel TCL Hardware Repair | 6 | 11-13-2001 20:37 |
6150 Problems. Pls help | Hanukkah | Nokia Hardware & Hardware Repair | 11 | 07-27-2001 11:47 |
