Old 06-21-2010, 13:02   #1 (permalink)
Member: 397862
Thanks Meter: 176
5130cs
5130cs show logs is here
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35521203235039
Original Product code: 0577793
Bluetooth ID: 0025CF6116B7
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 35521203235039-1
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Old 06-21-2010, 14:42   #2 (permalink)
bireun's Avatar
Member: 796141
Thanks Meter: 25
This SL3. Not support yet with mx-key
Old 06-21-2010, 14:43   #3 (permalink)
Member: 859094
Sonork: MTM303
Thanks Meter: 17
i have also same complaint sir then i do................
Old 06-21-2010, 15:14   #4 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
@imran_panipat........is No Life Poster;
already post and discusse 1000 times in forum
why not use search buuton..........?
The Following User Says Thank You to jaleelkuttikkar For This Useful Post:
Old 06-21-2010, 15:26   #5 (permalink)
Registered User
Member: 680336
Thanks Meter: 44
I Have Same ProbLem Here.
I Repaired Super Sd & SimLock Rpl But No Luck, See My Log.
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: **********-*
Product Code: 0585577
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SECURITY_TEST failed!
Old 06-21-2010, 15:41   #6 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
Language Pack:
- not available.
SIMLOCK invalid!
brothers............not you only this problem.................
90 % members have same problem....................all members waiting sl3 solution
why you post again again.................?use always search button
Old 06-21-2010, 15:55   #7 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
I think bro jaleel is right
discussed many times
must wait new update
Old 06-21-2010, 15:58   #8 (permalink)
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
If you are from pakistan you can contact to bro hasnain
he can solve your problem but paid help
5130c rh-112 flash needed melgsm Nokia Base Band 5 ( BB-5 ) 10 02-01-2011 14:50
help???how to unlock 5130c-2(rm-495) peter829 Universalbox 14 10-21-2009 23:31
5130c failed to flash with usb shachash MT-BOX 5 09-02-2009 19:12
5130c k.p ic GSMONNITIN Nokia Hardware & Hardware Repair 0 04-08-2009 19:04
Page generated in 0.17727 seconds with 9 queries
