Old 03-31-2010, 23:15   #1 (permalink)
abdeslam728's Avatar
Member: 653776
Sonork: 100.1584146
Thanks Meter: 94
5130xm rm-495 turns off
5130xm rm-495 freezes & turns off after 3 to 5 min. i wrote rpl without npc, authorized & repaired sd + wrote good modified pmn and flashed to the latest version & still no chance
any idea?
Old 03-31-2010, 23:19   #2 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro, click scan and poste here log
Old 03-31-2010, 23:28   #3 (permalink)
Member: 653776
Sonork: 100.1584146
Thanks Meter: 94
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.94 21-07-09 RM-495 (c) Nokia
Imei plain: 35524603047573-5
Product Code: 0571584
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355246030475735
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-31-2010, 23:33   #4 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro, self test log pls
Old 03-31-2010, 23:51   #5 (permalink)
Member: 653776
Sonork: 100.1584146
Thanks Meter: 94
Phone Type:
SW version:
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N !no signal
20 BACKUP_BATT N passed
43 LCD N passed
21 LPRF_IF N passed
44 LPRF_AUDIO_LINES N passed
2 CURRENT_CONS N passed
42 RADIO N passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N passed
96 HOOKINT N passed
88 TAHVOINT Y passed
101 BTEMP N passed
119 IIC N passed
108 EXT_DEVICE N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
80 CDSP_TX_PLL_PHASE_LOCK N passed
81 CDSP_RX_IQ_LOOP_BACK N passed
77 CDSP_GSM_TX_POWER N !unknown(5 5) -
The Following User Says Thank You to abdeslam728 For This Useful Post:
Old 03-31-2010, 23:58   #6 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
bro, make sure memory card out then i think u need rehot flash
becerful
Old 04-01-2010, 00:01   #7 (permalink)
Member: 653776
Sonork: 100.1584146
Thanks Meter: 94
becerful
thx for ur help br. im bad when it comes to hardware matters , may u show me which IC exactly plz?
Old 04-01-2010, 00:04   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
about whit one IC ??
i thinks must check by service manual to make sure,where is the actually problem
br,
I need nokia 5130 RM-495 modefied pm file 120-308 blast.gsmhost MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-05-2010 15:21
5130c rm-495 contact servis solution step by step al_shi_me MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-31-2010 17:32
N70 Rm-84 turn off help plz parand Nokia Base Band 5 ( BB-5 ) 5 07-22-2009 22:46
Page generated in 0.15861 seconds with 9 queries
