09-21-2011, 09:45 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 5220 contact service need help ## (ANSWERED) Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35684002503393-6 Product Code: 0563611 Battery voltage: 4762 mV, current: 61 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-21-2011, 10:55 | #2 (permalink) |
Member: 900083 Status: Offline Thanks Meter: 601 | SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! MXKEY Serial: [FT SCR2000 0] - C0807C8F Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: uhci:hub:hub:UFS2XX, ver: 1.6.20.0 , NTMP ver: 1.6.20.1 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Product: V 07.23 17-07-09 RM-411 (c) Nokia Using cached productData. PUBLIC ID: 0F60001808827C561B91E4849F0CC4CCAEAB0B1D PRIVATE ID: A00FD302FB782DBAB13EE90DBF9FBC7947183677 E-FUSE: 025B2301 SEC ROM CRC: 40830040 Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.7 [CR2]BB5 remaining credit: 38 Completed in 4.765 s RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-411_356840025033936_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-21-2011, 11:06 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | before continuing the discussion, please update your mxkey software. you are using old buggy version. http://forum.gsmhosting.com/vbb/f550...luded-1323642/ BR |
09-21-2011, 11:24 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | Write full pm with 120 lock aria dont skip option when write pm rewrite simlock data than go serivece tab select imei&security select simlock tick on simlock rpl than repair simlock than init sim lock your set will be done |
09-21-2011, 11:25 | #5 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | Mate do according this procedure: 1_ Take backup of your RPL only NPC not All section 2_Reset all from Certificate tab but before you must had taken NPC backup 3_Write your NPC backup and the simlock rpl which is already calculated from server and saved in > C:\mobileEx\3.5\data\backup 4_Scan phone and see if still SL was damaged repair it 5_ Repair SD and write modified PM after PM Auth Your problem will be solved WBR |
09-21-2011, 16:48 | #6 (permalink) | |
Member: 900083 Status: Offline Thanks Meter: 601 | Quote:
09-21-2011, 16:50 | #7 (permalink) | |
yes dear try it but same Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35684002503393-6 Product Code: 0563611 Battery voltage: 4774 mV, current: 55 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
09-21-2011, 18:38 | #8 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 368 | mate fully erase the phone after erasing fully flash and restore only npc of rpl not complete rpl now repair SL and SD and recover cert and write modefied pm after pm authorization. wBR |
09-22-2011, 22:05 | #9 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
would you share your computer configuration? PC hardware and all installed program. We'll try to reproduce the same error. Since this is a serious problem for us. - sorry for this - please have a try: - backup rpl: select RAP. - erase flash: get addr > select all, un mark safe erase. - reflash with the latest version - repair SP Lock, mark make simlock rpl, mark PA_SL2 - proceed to SD repair and DCC write. BR | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
