Old 02-20-2010, 11:59   #1 (permalink)
Member: 381846
Sonork: 123.786786
Thanks Meter: 54
Post 5220 CONTACT SERVIS not solve with uB AND MX-KEY[SOLVED]
how to solve 5220 contact service pls tell me in littel steps here is logs
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
thanks pls help me
Old 02-20-2010, 12:05   #2 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK_TEST passed
thanks pls help me
see here bro can solve easyly http://forum.gsmhosting.com/vbb/showthread.php?t=932107
Old 02-20-2010, 12:07   #3 (permalink)
prince_arsalan's Avatar
Member: 618626
Sonork: 100.1592779
Thanks Meter: 61
Make Pmm Auth And Write P.M Field 1 And 309...............
Old 02-20-2010, 12:08   #4 (permalink)
MR.MAMUN's Avatar
Member: 548479
Thanks Meter: 138
SIMLOCK_TEST passed
1st input 5220 xpress music Full Modified PM.pm
pm sx4auto then write pm problem 100% solved
problem not solved loog send
Old 02-20-2010, 12:10   #5 (permalink)
revocell's Avatar
Member: 898057
Sonork: unvailable
Thanks Meter: 85
super sd auth and write pm only 1-309 .. if not solved maybe u r phone missing hwc&ccc
just upload hwc & ccc with same phone and retry sd auth and write pm.
Old 02-20-2010, 12:12   #6 (permalink)
Member: 381846
Sonork: 123.786786
Thanks Meter: 54
not worke PPMAUTH
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 119.152.112.79
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
ppm ahuth not make
Old 02-20-2010, 12:17   #7 (permalink)
Member: 618626
Sonork: 100.1592779
Thanks Meter: 61
No SX4 Card found.
ppm ahuth not make
Repair SD...............
Make Super Sd Auth Write Modified P.M...............
Old 02-20-2010, 12:28   #8 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
SIMLOCK_TEST passed
thanks pls help me
if u tried all steps and no success
than upload RPL here on forum
will see what could we do
Old 02-20-2010, 12:30   #9 (permalink)
Registered User
Member: 82317
Thanks Meter: 15
just one click on unlock repeir your fon will be ok,,,,,,,,,,,,,ub
Old 02-20-2010, 12:30   #10 (permalink)
Fune4u's Avatar
Member: 278548
Sonork: 100.1583183
Thanks Meter: 948
No SX4 Card found.
ppm ahuth not make
Mack Super SD Auth
Writh pm
probile slove
Old 02-20-2010, 12:31   #11 (permalink)
Member: 381846
Sonork: 123.786786
Thanks Meter: 54
i did with ub but not not ok i loss my credit
Old 02-20-2010, 12:32   #12 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
write clone rpl ,
make simlock repair
make sd repair and upload pm 1 and 309 with super sd auth
Old 02-20-2010, 12:38   #13 (permalink)
Member: 381846
Sonork: 123.786786
Thanks Meter: 54
now this is log any body tell me where is 1 to 309 how to write phone is same on contact service pls send image or easy steps thanks This phone have PM308 protected, SD security in not restorable.
SIMLOCK_TEST passed
Old 02-20-2010, 12:46   #14 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
with same proceedure of repairing contact service
1. i made fully back up, pm, certificate, and rpl,
2. go to pm read all neccessary data, reset pnc, will roose imei, do not worry, imei will turn to 1235,
3. erase flash then full flash , imei will still corrupted,
4. restore imei from back up , repair sd,
5. turn to pm load the pm, activate superdongle, then write pm ( search pam from NOKIA BB5 PM Tested by Chevka) it help so much
6. Reset the phone, check igf all security passed,
Old 02-20-2010, 12:50   #15 (permalink)
Member: 381846
Sonork: 123.786786
Thanks Meter: 54
Thanks every one i m really very happy
SPEACAL THANKS MX-TEAM AND ALL THOSE WHO HELPO ME i NEVER FORGET HTNAKS BROTHER,S I REMBER IT THANKS FOR HELP ME THANKS NOW PHOE IS OK AND HERE IS OK LOGS
SIMLOCK_TEST passed
SECURITY_TEST passed
Provider: Nokia Test, Country: FinlandCounter: 0/3, 0/10
CONFIG_DATA: 2440700000000000PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFFBLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
THANK U VERY MUCH
HELLO MX-TEAM ! Can MX-KEY Solve 2630 Contact Service? amit123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 09-13-2010 22:05
5220 contect service solved with ub masterspargo Universalbox 1 02-14-2010 12:13
3120c SECURITY_TEST failed! NOT solved by MX KEY[SOLVED] akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-11-2010 07:33
i'm not happy with bb unlocking mx key (because i activated my fg dongle with 99 EUR) unlock & flash MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 41 02-01-2010 22:25
Help solve the problem with running the MX-KEY ostapchikyra MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 12-18-2009 12:54
Page generated in 0.25936 seconds with 9 queries
