Old 09-11-2009, 09:53   #1 (permalink)
Member: 685851
Thanks Meter: 10
5220 Contact Servive..SUCCESS..without RPL
5220 contact servive...success without RPL
this LOG in CONTACT SERVICE
Using device: J.A.F, FW ver: 01.B1
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 127002138E9F0254B290C2EECBDDEB6A078D3A86
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Original Imei: 35366201022785
Original Product code: 0563666
Bluetooth ID: 0021ABE49D2D
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 06.51 23-03-09 RM-411 (c) Nokia
Imei plain: 35366201022785-8
Product Code: 0563666
VariantId: X
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
SIMLOCK seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
This LOG after repair
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
SW Version: V 05.63 12-01-09 RM-411 (c) Nokia
VariantId: X
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei: 353662010227858
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 8 Users Say Thank You to eSWe For This Useful Post:
Old 09-11-2009, 11:28   #2 (permalink)
Member: 698592
Sonork: 100.1645954
Thanks Meter: 18
thanks ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 09-11-2009, 11:59   #3 (permalink)
Member: 699730
Thanks Meter: 3
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
VariantId: X
Language Pack:
- not available.
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
VariantId: X
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
wacthdog sir...:con fused::con fused:
Old 09-11-2009, 12:32   #4 (permalink)
prakashmborana's Avatar
Member: 600436
Thanks Meter: 219
writte backuped rpl i hope ok ur backuped rpl is working
Old 09-11-2009, 12:39   #5 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
luckenough..to sucess
Old 09-11-2009, 15:27   #6 (permalink)
Member: 685851
Thanks Meter: 10
now..i m repair again my phone...and...
this LOG
VariantId: X
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 09-11-2009, 16:59   #7 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
everything is possible as long as you have "the one" from the first step.
it shows you still have Superdongle intact !!
congratulation hehehe....
Old 09-11-2009, 17:03   #8 (permalink)
Member: 597405
Thanks Meter: 20
what solution did you do..?
im confused,in thread your sharing your success repair,but cant see any solution posted.
thanks,
Old 09-11-2009, 17:10   #9 (permalink)
Member: 1060387
Thanks Meter: 11
WOW!!!!!!!!!!!!!!!!!!!1
great
Old 09-11-2009, 17:21   #10 (permalink)
Member: 629228
Thanks Meter: 17
solution how? do not just log it
Old 09-11-2009, 17:34   #11 (permalink)
Registered User
Member: 559397
Thanks Meter: 53
MAYBE YES.................... OR WHOLE BACKUP (UPDATE FOR mxkey v5)
Old 09-11-2009, 19:29   #12 (permalink)
neo_2005's Avatar
Member: 65656
Thanks Meter: 91
if both are valid, it is believed to be correct without RPL, so if you find an invalid, then the WD will likely occur.
Old 09-11-2009, 20:34   #13 (permalink)
Member: 685851
Thanks Meter: 10
dont you believe?????...its true...and reality...
My phone....now...normaly...without WD
i want share my solution...soon
please wait...
Old 09-11-2009, 20:38   #14 (permalink)
Member: 685851
Thanks Meter: 10
please wait...
Old 09-11-2009, 21:41   #15 (permalink)
mohA™'s Avatar
Member: 199405
Sonork: 100.1576571
Thanks Meter: 322
its very good info
thats mean more powerfull methods with sl2 protected
thanks mx team
nokia 5220 contact service successfully-for easy way MGT SOFTWARE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-22-2010 07:06
nokia 5220 contact service successfully MGT SOFTWARE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 01-30-2010 12:42
5220 contact service success deepak nagrani Universalbox 1 01-24-2010 12:31
5220 contact service... tried to solve by cyclone not RPL cal. mitch_md3 Cyclonebox 15 11-15-2009 13:40
5220 contact service after write rpl majidjony J.A.F. Plus 12 04-24-2009 08:29
Page generated in 0.36953 seconds with 10 queries
