5220 RM-411 Big problem need ur help All Original Product code: 0573571 Bluetooth ID: 002404428409 Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: 35684502356049-2 Product Code: 0563611 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted!:confused: |
1. Write pm using SUPER SD Auth (without 120,308 block) 2. Service- IMEI & Security- Simlock- Init Simlock - make simlock rpl - Update Splock |
5220 RM-411 SIMLOCK_TEST failed! SECURITY_TEST failed slution im tested Complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. BR parwez |
Dear Bro, Use this very useful link http://forum.gsmhosting.com/vbb/showthread.php?t=921075 Today myself tested 5220 Rm-411 its all done SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY Thanks MX-Key Team |
Problem solved it was too hard but it's fine and the phone is working Now :) 5220 RM-411 SIMLOCK_TEST failed! SECURITY_TEST failed slution im tested Complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. BR parwez |
