Old 02-10-2010, 13:55   #1 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
5220 RM-411 Big problem need ur help All
Original Product code: 0573571
Bluetooth ID: 002404428409
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35684502356049-2
Product Code: 0563611
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
The Following User Says Thank You to G$m For This Useful Post:
Old 02-10-2010, 14:06   #2 (permalink)
Member: 208883
Thanks Meter: 3
1. Write pm using SUPER SD Auth (without 120,308 block)
2. Service- IMEI & Security- Simlock- Init Simlock - make simlock rpl - Update Splock
The Following User Says Thank You to dozda2005 For This Useful Post:
Old 02-10-2010, 15:28   #3 (permalink)
pinkyelectronic's Avatar
Member: 1173492
Thanks Meter: 27
5220 RM-411 SIMLOCK_TEST failed!
slution im tested
Complete repair damaged simlock by MXkey except SL3:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
parwez
The Following User Says Thank You to pinkyelectronic For This Useful Post:
Old 02-10-2010, 16:22   #4 (permalink)
Member: 447009
Sonork: 100.1591307
Thanks Meter: 35
Dear Bro,
Use this very useful link
6120c \SD Repair\Security Repair\SimLock Invalid\All Solution By MX-KEY
Today myself tested 5220 Rm-411 its all done
Thanks MX-Key Team
The Following User Says Thank You to libran_s26 For This Useful Post:
Old 02-11-2010, 13:45   #5 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
Problem solved it was too hard but it's fine and the phone is working Now
slution im tested
1. Backup RAP NPC
2. FULL ERASE
4. Restore IMEI
5. Repair SPLock
6. Repair SD
7. Super SD Auth
parwez
i900 big problem need urgent help sameenshah123 HTC & Smartphones ( WM Without Touch) 3 08-11-2009 18:02
i900 big problem need urgent help sameenshah123 UST Pro II 4 08-02-2009 15:28
Nokia 5220 RM-411 rigtone problem kad-kad Nokia Hardware & Hardware Repair 0 12-21-2008 10:13
R380 big problem. need urgent help. IceKiller ZLIN Old Ericsson Phones & Sony Phones 2 10-05-2002 17:28
Page generated in 0.28116 seconds with 8 queries
