Old 02-03-2010, 16:14   #1 (permalink)
Member: 445943
Thanks Meter: 25
5220 SIMLOCK_DATA corrupted! plz help
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 21600118B31B03541A9C6ED2A589B99AA94C2012
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Original Imei: 35366201620239
Original Product code: 0563614
Bluetooth ID: 0021ABEDBAFB
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35366201620239-2
Product Code: 0563540
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
Old 02-03-2010, 16:25   #2 (permalink)
Code:L.A 22's Avatar
Member: 990900
Thanks Meter: 540
1st: SD REPAIR
2nd: SUPER SD AUTH.
3rd: Write PM w/o 308
Old 02-03-2010, 16:41   #3 (permalink)
Member: 154346
Thanks Meter: 37
SW Version: V 06.51 23-03-09 RM-411 (c) Nokia
Imei plain: xxxxxxxxxxxxxxxxxx
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 3xxxxxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello xxxxxxxxxxxxxxxx
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-03-2010, 16:46   #4 (permalink)
Member: 99639
Thanks Meter: 20
plz halp me nokia 5220 SECURITY_TEST failed!
SIMLOCK_TEST passed
SECURITY_TEST failed! with mx kay
Old 02-03-2010, 16:49   #5 (permalink)
Crazy Poster
Member: 1210570
Thanks Meter: 3
Post
Same problem here
pls help
Old 02-03-2010, 17:20   #6 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
solution here
http://forum.gsmhosting.com/vbb/showthread.php?t=851550
The Following User Says Thank You to GSM PAVIA For This Useful Post:
5220 SIMLOCK_DATA corrupted! misbah123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 01-27-2010 11:10
7210c SIMLOCK_DATA corrupted! plz help me kabul MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-26-2010 09:05
5220 SIMLOCK_DATA corrupted! maruti82 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 30 01-25-2010 12:29
5220 SIMLOCK_DATA corrupted MR.MAMUN Nokia Base Band 5 ( BB-5 ) 2 01-20-2010 10:12
5220 SIMLOCK_DATA corrupted! Frenzy_2020 Universalbox 2 12-02-2009 18:31
Page generated in 0.21226 seconds with 10 queries
