Old 06-02-2011, 14:37   #1 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
5230 dead after flashing (ANSWERED)
5230 was working and not locked,
now dead with SP data corrupt
Flashing log all is ok
I want to repair Sd but i have server error:
Failed to read SP data
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 4] - C0xxxx
Using device: HTI BOX, FW ver: 00.08
Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
Product: V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia
ApeCoreSw: V 40.9.003
Using cached productData[12C000180DA300529E8D91E88239D54AF365D8FD] ...
ERROR: could not get data from server!
Old 06-02-2011, 14:47   #2 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
sorry, my error, it is rm-625, i flashed it with rm-588
Only mxbox can flash it with fbus, mtbox can't start to flash
Old 06-02-2011, 15:24   #3 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
there isn't chance to revive it?
Flashing with his original product code, it is dead and not go in loca lmode
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 5] - C0xxxxx
Processing MCU file: RM-625_40.9.003_prd.core.C00
[BB5,XSR 1.6] size: 92.37 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 12C000180DA300529E8D91E88239D54AF365D8FD
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 10.32.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
TransmissionMode: DDR&TX2
FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT
ALG [35]: XSR 1.5
Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 10.32.0 revision: 2.0 size: 0x8B828
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT MuxOneNAND area [00040000-00082FFF]
CMT MuxOneNAND area [00083400-003FFFFF]
CMT MuxOneNAND area [00400000-007FFFFF]
CMT MuxOneNAND area [00800000-00D5FFFF]
CMT MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7DC72D3FDC552426A4479BC820097D304CFB6C15 (RAP Certificate version) sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 4 min 14.140 s
Processing PPM file: RM-625_40.9.003_prd.rofs2.V25
[BB5,XSR 1.6] size: 26.32 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ALG [35]: XSR 1.5
Erase size: 36.50 MB
CMT MuxOneNAND area [06CE0000-0915FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 1 min 14.500 s
Processing PPM file: RM-625_40.9.003.548.02.rofs3.fpsx
[BB5,XSR 1.6] size: 6.38 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ALG [35]: XSR 1.5
Erase size: 13 MB
CMT MuxOneNAND area [09160000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 18.234 s
Processing CNT file: RM625_40.1.003_001_003_U002.uda.fpsx
[BB5,XSR 1.6] size: 9.37 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ALG [35]: XSR 1.5
Erase size: 86.12 MB
CMT MuxOneNAND area [09E60000-0F47FFFF]
Programming completed in 27.594 s
Total time for flashing process(boot+erase+write) was 7 min 0.703 s
Phone not responding !
Old 06-02-2011, 18:23   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
try to apply BB5 RAP3 Nand erase from quick fix.
The Following User Says Thank You to gbluez For This Useful Post:
Old 06-03-2011, 07:56   #5 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
i tryed but not work, it say is not rap3 phone
Old 06-03-2011, 15:45   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
OK,
flash it as MCU,
setting: skip HW_CFG.
http://forum.gsmhosting.com/vbb/atta...2&d=1305143350
will be fixed on next release, it should be quick fix supported
Old 06-03-2011, 21:45   #7 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
thanks bro, i will try,
so you think after nand erase, sp data will not result corrupt?
Old 06-03-2011, 22:45   #8 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 276
You hawe backup Rpl?
Old 06-03-2011, 23:36   #9 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
no, i haven't rpl backup
Old 06-03-2011, 23:56   #10 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 276
not good.
always the first backup rpl an other protection
you phone is nokia 5230 or 5233 ???
prob flash with orginal product code firmware or latest firmware. with dead usb.
not work.
prob my solution
Complete repair damaged simlock(except SL3 at moment) and superdongle by mxkey:
1. Backup RAP NPC
Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL
2. FULL ERASE
Flash > Advance : untick safe ERASE > Erase Flash
3. Flash MCU,PPM,CNT
4. Restore IMEI
Service > Imei & Security > Imei Rebuild > Restore Imei
5. Repair SPLock
Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock
6. Repair SD
Service > Imei & Security > Imei Rebuild > Repair SD
7. Super SD Auth
Service > PM > Super SD Auth
8. When super SD auth is done, write PM imediately.
I tested this by SL2!!!!!!
only these new versions have a bug. I do not know whether everything works as before ..
I not tested the new version of mobileEX..
Old 06-04-2011, 07:52   #11 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
is 5228
flashing with 5230 rm-588 it dead but go in local mode
flashing with 5228 last version original product code, it is dead and no local mode
Old 06-04-2011, 08:32   #12 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 276
uploaded.to - where your files have to be uploaded to
flash ..dead usb ...full batery
prob other box.like hwk.ub.atf...mx-key fixsing bug
The Following User Says Thank You to sajohaker For This Useful Post:
Old 06-04-2011, 08:56   #13 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 276
Nokia 5228 5232 5233 RM-625 firmware data package download - CPKB - Cell Phone Knowledge Base
4.1 EURO
4.2 MEA
4.3 APAC
4.4 CHINA
4.5 CHINA 2G
4.6 AMS
4.7 AMS 2G
4.8 CMCC 2G
4.9 SWAP
4.10 ENO
Old 06-04-2011, 14:06   #14 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 104
flashing with rm-625 40.1.003 it dead
flashing with rm-588 it dead but go in local mode
Old 01-26-2013, 11:12   #15 (permalink)
Member: 1639593
Sonork: 100 1622630
Thanks Meter: 6
when i conect on ms box my nokia 5230 rm-588 it directly show local mode.its info. all ok but never open it on normal mode. ANY SOLUTION PLEASE
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 21:24
Page generated in 0.46473 seconds with 8 queries
