03-21-2012, 09:46 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Location: at home
Member: 56735 Status: Offline Thanks Meter: 35 | 5230 only vibrate after flashed with 5800 i have accidently flash nokia 5230 with 5800 firmware and now phone only vibrate. i've flash them with 5230 firmware but still same what can i do please need ur help br |
03-21-2012, 10:12 | #2 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | do u have rpl back up? if u tick safe flash when flashed it, u must have it. try erase flash bro. - full erase: (Flash, Advance tab)get addr, don't mark safe erase. ERASE! - full flash (MCU,PPM,CNT use market drop down), write good PM, restore imei. if u dont have back up rpl, dont try above steps. br |
03-21-2012, 10:31 | #3 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C CMT SYSTEM ASIC ID: 000000010000022600000001020C192102054100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1C4000093CFF55408D435FB5C3382D0AA61462E5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35593604682680_CE RT.rpl" CMT PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 37.69 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0025FFFF] CMT FLASH,MuxOneNAND area [003E0000-005DFFFF] CMT FLASH,MuxOneNAND area [005E0000-010DFFFF] CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF] CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF] CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF] CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CEFA9C41 [RAP Certificate 193 v.1] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 33.344 s Processing PPM file: rm540__08.54.ppm_meac [BB5,XSR 1.6] size: 5.29 MB Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 6.703 s Processing CNT file: rm540__08.54.image_meac_0583978_006 [BB5,XSR 1.6] size: 14.10 MB Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 18.140 s Total time for flashing process(boot+erase+write) was 1 min 11.343 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia X3 USB Phonet, PORT_ID: AC31ACE Verifying communication to device OK. Phone type: RM-540 (Nokia X3-00) SW version: V 08.54 25-10-10 RM-540 (c) Nokia Imei plain: 35593604682680-2 Product code: 0584329 Battery voltage: 3973 mV, current: 78 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR030C20C607, ver: 003.003 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355936046826802 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
03-21-2012, 10:31 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. do as above & still remain same then post buscheck log, there is one more method to recover from that needs log. |
03-21-2012, 10:33 | #5 (permalink) |
Member: 1488757 Status: Offline Thanks Meter: 98 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C086CBB7 Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.13703(05-01-2012) Processing MCU file: rm618__08.25.mcusw [BB5,XSR 1.6] size: 26.97 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000C905A8707A21B030DB440420D3D49B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35699004271783_CE RT.rpl" CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 32.88 MB CMT MuxOneNAND area [00000000-0001FFFF] CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-011BFFFF] CMT MuxOneNAND area [011C0000-01CFFFFF] CMT MuxOneNAND area [02500000-028FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: E9700989029D9E899915F781B1582048E042A738 (RAP Certificate v1 237) sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT ADA block sent CMT RAP3NAND block sent CMT ISA+DYNSW block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT UPDAPP block sent Programming completed in 34.266 s Processing PPM file: EF875EA1_rm618__08.25.ppm_l [BB5,XSR 1.6] size: 5.59 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT MuxOneNAND area [01D00000-024FFFFF] Flash programming ... Programming completed in 7.062 s Processing CNT file: 476DD01F_rm618__08.25.image_l_059F9H6_002 [BB5,XSR 1.6] size: 18.24 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 76.31 MB CMT MuxOneNAND area [02900000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 22.921 s Total time for flashing process(boot+erase+write) was 1 min 15.421 s Waiting for device boot up ... Device found: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 25FB989E Verifying communication to device OK. Phone Type: RM-618 (Nokia X2-00) SW Version: V 08.25 19-05-11 RM-618 (c) Nokia Imei plain: 35699004271783-7 Product Code: 0595309 Battery voltage: 3679 mV, current: 1 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356990042717837 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
03-21-2012, 10:36 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. what is the status now after doing above procedure. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
03-21-2012, 11:03 | #8 (permalink) |
Member: 1488757 Status: Offline Thanks Meter: 98 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C086CBB7 Using device: USB ROM and HTI, FW ver: 00.50, SN: 000144E9 Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 100002072699034480307D61FF475E2D94399CF9 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C26DC8C FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35375704928332_CE RT.rpl" CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 57.188 s Processing PPM file: rm645_071.005_01.01_Euro1_prd.rofs2.fpsx [BB5,XSR 1.6] size: 40.99 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 50.250 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 2.015 s Total time for flashing process(boot+erase+write) was 3 min 0.672 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID: 12CEBB65 Verifying communication to device OK. Phone type: RM-645 (Nokia C5-00) SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia Imei plain: 35375704928332-6 Product code: 0593572 Battery voltage: 3841 mV, current: 173 mA ApeCoreSw: 071.005 Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353757049283326 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
Samsung e2210b after flash camera fail,tried 4 files from support.still same. | xavi29 | Z3X-Team Products | 9 | 12-11-2013 17:07 |
need flash file micromax x262 | parth gupta | Infinity-Box | 4 | 01-31-2013 16:09 |
11W48 E15i dead after unlocking !!! | vtomi | JTAG-PRO aka GPGJTAG | 5 | 04-03-2012 20:28 |
p7500 proble after flash with root file [SOLVED] | sameenshah123 | SPT BOX | 8 | 03-20-2012 21:46 |
Samsung e2210b flash files need,did not found in support [Answered] | xavi29 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 03-20-2012 11:13 |
