09-15-2012, 15:13 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: punjab
Member: 271008 Status: Offline Thanks Meter: 280 | 5233 give info with fbus but not power up SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia ApeCoreSw: V 51.1.002 Imei plain: 35975904879596-5 Product code: 059D6Q5 Battery voltage: 4049 mV, current: 168 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Phone version(51.1.002) outdated, selected version is: 50.9.1 Imei net: 359759048795965 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN on/off switch is ok, it did not show charging any idea to solve this problem |
09-16-2012, 09:41 | #3 (permalink) | |
Member: 271008 Status: Offline Thanks Meter: 280 | here is the self test log Quote:
SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia ID Test name Startup Result 88 TAHVOINT Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 90 PWR_KEY N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 8 MBUS_RX_TX_LOOP Y !NO SIGNAL(06) 119 IIC N !NOT EXECUTED(03) 117 DIGIMIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 5 CAMERA_ACCELERATOR N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 59 MAIN_LCD_IF N !NOT EXECUTED(03) 60 TOUCH_STUCK N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 103 TOUCH_IF N !NOT EXECUTED(03) 104 ACCEL_IF N !NOT EXECUTED(03) 113 LCD_CONTROLLER N !NOT EXECUTED(03) 49 VIBRA N !NOT EXECUTED(03) 91 USB_LOOP N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) | |
