Old 01-11-2012, 12:09   #1 (permalink)
Member: 588045
Thanks Meter: 19
5233 vibrate only
5233 vibrate only
after flashing hanset ok v rm-625_51.1.002
iflash rm-625_51.9.001
flash comple but normal fild only vibrat itry 4 5 time fbus but no anser
itry usb but
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0857680
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00007D2F
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Processing MCU file: RM-625_51.1.002_prd.core.C00
[BB5,XSR 1.6] size: 95.97 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1580000412970052E24153A58B676D3C291168C0
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
S***ested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client...
Failed to add FUR client
synchronize file update
Definitions file is identical and up to date, no need an update.
plzzzhep me
Old 01-11-2012, 12:25   #2 (permalink)
Member: 545722
Sonork: 100.1619680
Thanks Meter: 322
Backup rpl and erase ,
try flash
Old 01-11-2012, 12:45   #3 (permalink)
Member: 588045
Thanks Meter: 19
flashing se pale back up liya tha erese kaker ke flash kiya but same
only vibret
Old 01-11-2012, 13:40   #4 (permalink)
mani19_za's Avatar
Member: 1689485
Thanks Meter: 42
if flashing complete then try this solution
Old 01-11-2012, 13:46   #5 (permalink)
Member: 1071783
Thanks Meter: 11
which version u flash
Old 01-11-2012, 13:46   #6 (permalink)
Member: 1071783
Thanks Meter: 11
u dont have backup dont o erase
Old 12-23-2013, 11:54   #7 (permalink)
Member: 1710992
Sonork: nibu
Thanks Meter: 25
check bsi print....100% working
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware Repair 7 04-12-2000 09:41
only 1800Mhz ?? dofie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-17-2000 21:51
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.16602 seconds with 10 queries
