Old 03-05-2010, 11:18   #1 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
5300 (RM-147) V 05.02 Unlock Failed
5300 (RM-147) V 05.02 MX-Key Unlock Failed
J.A.F 1.98.65 Unlock Done
Phone Type: RM-147 (Nokia 5300)
SW Version: V 05.02 05-06-07 RM-147 (c) Nokia.
Imei plain: 35696401187651-0
Product Code: 0546897
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356964011876510
Version: SIMLOCK SERVER VERSION 63
Provider: T-Mobile, Country: U.S.A.
Counter: 0/3, 0/10
CONFIG_DATA: 3102000000000000
PROFILE_BITS: 8000000000000000
BLOCK 1:   1=LOCKED (MCC+MNC): 310160, DATA=310160
BLOCK 2:   1=LOCKED (MCC+MNC): 310200, DATA=310200
BLOCK 3:   1=LOCKED (MCC+MNC): 310210, DATA=310210
BLOCK 4:   1=LOCKED (MCC+MNC): 310220, DATA=310220
BLOCK 5:   1=LOCKED (MCC+MNC): 310230, DATA=310230
BLOCK 6:   1=LOCKED (MCC+MNC): 310240, DATA=310240
BLOCK 7:   1=LOCKED (MCC+MNC): 310250, DATA=310250
BLOCK 8:   1=LOCKED (MCC+MNC): 310260, DATA=310260
BLOCK 9:   1=LOCKED (MCC+MNC): 310270, DATA=310270
BLOCK 10:   1=LOCKED (MCC+MNC): 310300, DATA=310300
BLOCK 11:   1=LOCKED (MCC+MNC): 310310, DATA=310310
BLOCK 12:   1=LOCKED (MCC+MNC): 310490, DATA=310490
BLOCK 13:   1=LOCKED (MCC+MNC): 310530, DATA=310530
BLOCK 14:   1=LOCKED (MCC+MNC): 310580, DATA=310580
BLOCK 15:   1=LOCKED (MCC+MNC): 310590, DATA=310590
BLOCK 16:   1=LOCKED (MCC+MNC): 310640, DATA=310640
BLOCK 17:   1=LOCKED (MCC+MNC): 310660, DATA=310660
BLOCK 18:   1=LOCKED (MCC+MNC): 310800, DATA=310800
Counter: 0/3, 0/10
Backup saved to "BB5_35696401187651_SIMLOCK.back"
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
Product: V 05.02 05-06-07 RM-147 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes)  ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x3948 bytes)  ...OK
Sending CustomLoader(0x50B0 bytes)  ...OK
Sending SecurityBlock(0x2000 bytes)  ...OK
Sending SimlockBinary(0x3B0 bytes)  ...OK
Calculating LOCK data ...Update SPLOCK failed, you can try to upgrade/downgrade phone and retry !
Reading Simlock info ...
Counter: 0/3, 0/10
MCU SW version: V 05.02
05-06-07
RM-147
(c) Nokia.
HW version: 3004
PCI version:
RFIC version:     17211721
DSP version: pb06w14v51
PPM version: V 05.02
05-06-07
RM-146
(c) Nokia.
NTM
Retu version: 32
Tahvo version: 53
Content Pack version: Content: TMO v4
16-11-07
RM-147
(c) Nokia.
Production serial number: RNC090474
Product code: 0546897
Module code: 0203052
Basic production code: 0530539
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356964011876510
IMEI spare to net: 3A 65 69 04 11 78 56 01
IMEI SV to net: 33 65 69 04 11 78 56 11 F0
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 3102000000000000
Provider: T-Mobile;U.S.A.
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 310160
Block 2:
Lock 1: CLOSED -> Lock Data: 310200
Block 3:
Lock 1: CLOSED -> Lock Data: 310210
Block 4:
Lock 1: CLOSED -> Lock Data: 310220
Block 5:
Lock 1: CLOSED -> Lock Data: 310230
Block 6:
Lock 1: CLOSED -> Lock Data: 310240
Block 7:
Lock 1: CLOSED -> Lock Data: 310250
Block 8:
Lock 1: CLOSED -> Lock Data: 310260
Block 9:
Lock 1: CLOSED -> Lock Data: 310270
Block 10:
Lock 1: CLOSED -> Lock Data: 310300
Block 11:
Lock 1: CLOSED -> Lock Data: 310310
Block 12:
Lock 1: CLOSED -> Lock Data: 310490
Block 13:
Lock 1: CLOSED -> Lock Data: 310530
Block 14:
Lock 1: CLOSED -> Lock Data: 310580
Block 15:
Lock 1: CLOSED -> Lock Data: 310590
Block 16:
Lock 1: CLOSED -> Lock Data: 310640
Block 17:
Lock 1: CLOSED -> Lock Data: 310660
Block 18:
Lock 1: CLOSED -> Lock Data: 310800
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-147.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-147\
Searching for default location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\\Products\RM-147\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
Backup simlock data first...
Reading IMEI...
Failed! Aborting!
Can't backup simlock data!Abort!
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\RM-147_356964011876510_05.02_LCK_backup.pm
Done!
Reading simlock data...
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Block 8:
Block 9:
Block 10:
Block 11:
Block 12:
Block 13:
Block 14:
Block 15:
Block 16:
Block 17:
Block 18:
Reading data...
Booting phone...
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
SPLA Unlock codes:
#pw+012068104729618+1#
#pw+272935276210846+2#
#pw+182719257650293+3#
#pw+903451482045602+4#
#pw+936491098468316+5#
#pw+318836377991521+6#
#pw+195043262651723+7#
Uploading code to phone...
Waiting for phone...
Reading soft info...
Unlocking...
Reseting phone....
LOCK STATUS:
Block 1:
Lock 1: OPEN
Block 2:
Lock 1: OPEN
Block 3:
Lock 1: OPEN
Block 4:
Lock 1: OPEN
Block 5:
Lock 1: OPEN
Block 6:
Lock 1: OPEN
Block 7:
Lock 1: OPEN
Block 8:
Lock 1: OPEN
Block 9:
Lock 1: OPEN
Block 10:
Lock 1: OPEN
Block 11:
Lock 1: OPEN
Block 12:
Lock 1: OPEN
Block 13:
Lock 1: OPEN
Block 14:
Lock 1: OPEN
Block 15:
Lock 1: OPEN
Block 16:
Lock 1: OPEN
Block 17:
Lock 1: OPEN
Block 18:
Lock 1: OPEN
Done!
6085/ RM-RM-198/V 05.02 08-05-07 Can't Unlock .:Towhid:. JAF No Tp Unlocker by Cinek 3 03-24-2009 18:23
6085/ RM-RM-198/V 05.02 08-05-07 Can't Unlock .:Towhid:. J.A.F. By Jafsupport.com 0 03-24-2009 15:54
succefull unlock Nokia 5300b Rm-147 v 5.02 mariopaz22 BB5BOX 0 01-19-2008 01:02
5300 rm 147 supportbox MT-BOX 1 12-15-2007 08:18
5300 RM-147 dead Zukison14 MT-BOX 0 07-14-2007 00:16
Page generated in 0.21433 seconds with 9 queries
