5310 camera on stand by pls help i useing this file NIMMIIIIRRFF06150110.dcc but all time Camera Configuration file write failed ! whay is the step for write this file also if i am press scean show no dynamic camera configaration file found here is my phone info Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 08.32 23-07-08 RM-303 (c) Nokia Imei plain: 35681702746813-8 Product Code: 0564404 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed pls help |
dear read ur camera file with working 530 mobile then write it,ur file is not good. |
1 Attachment(s) 5310 Camera Configuration file write failed Me to face this problem when try to read or write file on camera in 5310 here is the log.. Version Info: MCU SW version: V 09.42 07-11-08 RM-303 (c) Nokia HW version: 2014 RFIC version: 064c0609 DSP version: ICPR71_08w30 LCD version: SEIKO PPM version: V 09.42 07-11-08 RM-303 (c) Nokia M5 BT MCM version: 2222-143 Retu version: 15 Tahvo version: 22 Content Pack version: Content: i_red V 09.42 07-11-08 RM-303 (c) Nokia Product Info: Production serial number: KPB365468 Product code: 0547038 Module code: 0203414 Basic production code: 0544850 Long production SN: 0 Serial Numbers: IMEI plain: 351934037207169 IMEI spare to net: 3A 15 39 04 73 02 17 06 IMEI SV to net: 33 15 39 04 73 02 17 66 F1 Other Info: Model : Nokia 5310 XpressMusic (Classic Phone) CS type : GSM900/GSM1800/GSM1900 BSI: 4.8 KOhm Imei net: 351934037207169 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Camera Configuration file write failed ! Camera Configuration file write failed ! here is the file the i read from 5310 it attached check it what is the problem...?? |
mostly losing in camera connecter |
Hello In this model ,it is camera connector problem many times. check camera status in its connector. |
