Old 02-10-2010, 10:10   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
5310 camera on stand by pls help
i useing this file NIMMIIIIRRFF06150110.dcc
but all time
Camera Configuration file write failed !
whay is the step for write this file
also if i am press scean show no dynamic camera configaration file found
here is my phone info
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 08.32 23-07-08 RM-303 (c) Nokia
Imei plain: 35681702746813-8
Product Code: 0564404
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
pls help
The Following User Says Thank You to unlock & flash For This Useful Post:
Old 02-10-2010, 19:24   #2 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 101
dear read ur camera file with working 530 mobile then write it,ur file is not good.
Old 02-10-2010, 20:02   #3 (permalink)
..::My3gtech::..'s Avatar
Member: 158032
Thanks Meter: 331
5310 Camera Configuration file write failed
Me to face this problem when try to read or write file on camera in 5310 here is the log..
Version Info:
MCU SW version: V 09.42 07-11-08 RM-303 (c) Nokia
HW version: 2014
RFIC version: 064c0609
DSP version: ICPR71_08w30
LCD version: SEIKO
PPM version: V 09.42 07-11-08 RM-303 (c) Nokia M5
BT MCM version: 2222-143
Retu version: 15
Tahvo version: 22
Content Pack version: Content: i_red V 09.42 07-11-08 RM-303 (c) Nokia
Product Info:
Production serial number: KPB365468
Product code: 0547038
Module code: 0203414
Basic production code: 0544850
Long production SN: 0
Serial Numbers:
IMEI plain: 351934037207169
IMEI spare to net: 3A 15 39 04 73 02 17 06
IMEI SV to net: 33 15 39 04 73 02 17 66 F1
Other Info:
Model : Nokia 5310 XpressMusic (Classic Phone)
CS type : GSM900/GSM1800/GSM1900
BSI: 4.8 KOhm
Imei net: 351934037207169
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
here is the file the i read from 5310 it attached check it what is the problem...??
Old 02-10-2010, 21:21   #4 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,282
Originally Posted by unlock & flash View Post
i useing this file nimmiiiirrff06150110.dcc
but all time
camera configuration file write failed !
phone type: rm-303 (nokia 5310 xpressmusic)
sw version: v 08.32 23-07-08 rm-303 (c) nokia
imei plain: 35681702746813-8
product code: 0564404
language pack:
- not available.
simlock seems to be valid
superdongle_key seems to be valid
simlock_test passed
security_test passed
pls help
post self tests result here
Old 02-10-2010, 22:08   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,224
mostly losing in camera connecter
Old 02-10-2010, 22:21   #6 (permalink)
mazmaz1's Avatar
Member: 339455
Sonork: 100.1589401
Thanks Meter: 84
Hello
In this model ,it is camera connector problem many times.
check camera status in its connector.
5310 wd repaired but camera on stand by StRaNgE PeRsOn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 02-13-2010 18:02
5310 wd repaired but camera on stand by StRaNgE PeRsOn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-13-2010 11:38
5310 wd repaired but camera on stand by StRaNgE PeRsOn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-13-2010 11:22
5310 camera on stand by T S dileep Nokia Hardware & Hardware Repair 1 09-19-2009 16:37
5310 camera on stand-by new solution Bastaphone Nokia Hardware & Hardware Repair 0 12-19-2008 12:12
Page generated in 0.27498 seconds with 9 queries
