5310 contact service ....... (answered) hi my 5310 is contact service, i m trying to auth pmm but faceing problem here is detail Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101013000 EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 18D00017DA078E56E7701F447B2AC504BFE27E98 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D Original Imei: 35800203488481 Original Product code: 0566173 Bluetooth ID: EC9B5B7B7A79 Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 10.10 23-03-09 RM-303 (c) Nokia Imei plain: 35800203488481-1 Product Code: 0547371 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358002034884811 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF here is error Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.102.16.126 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request what is problem and how can i slove plz guide |
Hi, RepAIR SD> Sd Auth > write pm 1 & 309. it Fail, Recover Certificate, if still fail , try this http://forum.gsmhosting.com/vbb/f550...l-here-945700/ |
cannot auth sd and pmm......y? Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 10.10 23-03-09 RM-303 (c) Nokia Using cached productData[18D00017DA078E56E7701F447B2AC504BFE27E98] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.102.16.126 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
Hi, Hi, RepAIR SD> Sd Auth > write pm 1 & 309. it Fail, Recover Certificate, if still fail , try this .::Solution for::. Security Test Fail .: HERE :. |
1- wirte rpl 2- RepAIR SD 3-Sd Auth 4- write pm 1 & 309 5- unlok again and will be ok tested 100% ok if u dont have pm and rpl just contact me i will upload them for u good work Recover Certificate, if still fail , try this |
I have the same problem - Contact Service SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! Can you upload PM and RPL? I will try your solution. |
1 Attachment(s) Quote:
Thanks my man It work like a charm |
Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3552********* Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! what about this |
Very NICE Thanks |
please help 5310 conser........ Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 05.81 06-02-08 RM-303 (c) Nokia Imei plain: 35207202021936-9 Product Code: 0547348 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352072020219369 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
we need further analysis. please run self test with following method: Service > Phone Test > Self test > Initialize > Select All > Run All > Detail. right click on result window, copy, and paste here your logs output. BR |
Phone Type: RM-303 (Nokia 5310 XpressMusic) SW Version: V 08.32 23-07-08 RM-303 (c) Nokia Imei plain: 3..............7 Product Code: 0548870 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Onto this there is a solution?:confused: |
no solution without rpl if u have backup then just restore it if u don't have rpl backup then u need to buy new rpl................... |
