Old 05-23-2010, 09:13   #1 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 74
Question 5310 contact service ....... (answered)
hi
my 5310 is contact service,
i m trying to auth pmm but faceing problem here is detail
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101013000
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 18D00017DA078E56E7701F447B2AC504BFE27E98
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
Original Imei: 35800203488481
Original Product code: 0566173
Bluetooth ID: EC9B5B7B7A79
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 10.10 23-03-09 RM-303 (c) Nokia
Imei plain: 35800203488481-1
Product Code: 0547371
Language Pack:
- not available.
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358002034884811
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
here is error
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 117.102.16.126
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
what is problem and how can i slove plz guide
The Following User Says Thank You to shami For This Useful Post:
Old 05-23-2010, 09:34   #2 (permalink)
Riteshgpt60's Avatar
Member: 1086393
Thanks Meter: 761
Hi,
RepAIR SD> Sd Auth > write pm 1 & 309. it Fail,
Recover Certificate, if still fail , try this
.::Solution for::. Security Test Fail .: HERE :.
The Following User Says Thank You to Riteshgpt60 For This Useful Post:
Old 05-23-2010, 09:44   #3 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 74
cannot auth sd and pmm......y?
Product: V 10.10 23-03-09 RM-303 (c) Nokia
Using cached productData[18D00017DA078E56E7701F447B2AC504BFE27E98] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
No SX4 Card found.
Old 05-23-2010, 09:52   #4 (permalink)
Member: 1086393
Thanks Meter: 761
Hi,
Hi,
Old 05-24-2010, 21:36   #5 (permalink)
m_choko's Avatar
Member: 88177
Sonork: 1594092
Thanks Meter: 65
Originally Posted by shami View Post
hi
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
here is error
No SX4 Card found.
i just repair one this day
1- wirte rpl
2- RepAIR SD
3-Sd Auth
4- write pm 1 & 309
5- unlok again
and will be ok tested 100% ok
if u dont have pm and rpl just contact me i will upload them for u
good work
The Following User Says Thank You to m_choko For This Useful Post:
Old 05-27-2010, 15:47   #6 (permalink)
Crazy Poster
Member: 675762
Thanks Meter: 8
I have the same problem - Contact Service
SIMLOCK invalid!
CMLA_KEY seems to be valid
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Can you upload PM and RPL? I will try your solution.
Old 05-27-2010, 19:21   #7 (permalink)
m_choko's Avatar
Member: 88177
Sonork: 1594092
Thanks Meter: 65
SIMLOCK invalid!
this is a good rpl and pm tested and ok 100/100
The Following 3 Users Say Thank You to m_choko For This Useful Post:
Old 06-05-2010, 12:16   #8 (permalink)
juniorljs's Avatar
Member: 992258
Thanks Meter: 20
Thanks my man
It work like a charm
Old 06-05-2010, 12:56   #9 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,196
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 3552*********
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
what about this
Old 06-05-2010, 13:25   #10 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 63
Language Pack:
- not available.
SIMLOCK invalid!
what about this
No solution yet.... wait........
Old 06-16-2010, 17:20   #11 (permalink)
gsmlander's Avatar
Member: 996551
Thanks Meter: 14
1- wirte rpl
2- RepAIR SD
3-Sd Auth
4- write pm 1 & 309
5- unlok again
good work
Good Job Thanks Bro . This solution work 100/100
Very NICE
Thanks
Old 11-20-2010, 04:08   #12 (permalink)
Member: 839145
Thanks Meter: 5
please help 5310 conser........
SW Version: V 05.81 06-02-08 RM-303 (c) Nokia
Imei plain: 35207202021936-9
Product Code: 0547348
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 352072020219369
Counter: 0/3, 0/10
Old 11-20-2010, 04:42   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
hello,
we need further analysis.
please run self test with following method:
Service > Phone Test > Self test > Initialize > Select All > Run All > Detail.
right click on result window, copy, and paste here your logs output.
Old 12-08-2010, 20:48   #14 (permalink)
UU2
Member: 21987
Thanks Meter: 27
SW Version: V 08.32 23-07-08 RM-303 (c) Nokia
Imei plain: 3..............7
Product Code: 0548870
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
Onto this there is a solution?
Old 12-09-2010, 04:47   #15 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 496
no solution without rpl
if u have backup then just restore it
if u don't have rpl backup then u need to buy new rpl...................
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 05-11-2000 03:43
gsm service provider sidou Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-30-2000 11:09
FREE SP unlock service timxy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-1999 16:05
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Page generated in 0.44146 seconds with 9 queries
