02-25-2010, 09:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | 5310 Contact Service Solution[SL3 phone,UNSUPPORTED yet] Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 05.80 18-12-08 RM-495 (c) Nokia Imei plain: 35417903307443-0 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! Any one tell me this problem solv solution |
The Following User Says Thank You to brokendreem For This Useful Post: |
02-25-2010, 09:48 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | yes it can be fixed but by some people not all can fix, special service required where are you from ? |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
02-25-2010, 09:52 | #6 (permalink) |
Banned Join Date: Sep 2004 Location: tunisia
Member: 81578 Status: Offline Thanks Meter: 78 | Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 3593290216xxxx-x Product Code: 0577xxx Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3593290216xxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF help me too in contact service |
The Following User Says Thank You to fay00 For This Useful Post: |
02-25-2010, 10:36 | #7 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | @fay00 man use this pm Use SUPER SD button, And then write this Pm, it would work |
02-25-2010, 17:04 | #9 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | there are SL3 phone Quote:
br, | |
5130c unlock problem[SL3 PHONE,UNSUPPORTED YET] | uzmantel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-21-2010 19:20 |
SIMLOCK_TEST failed! help[SL3 phone,UNSUPPORTED YET] | runner30 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-21-2010 10:06 |
5130 sp data corupted[SL3 PHONE,UNSUPPORTED YET] | delwar_us | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-20-2010 13:06 |
5130 @ valid RPl ...[SL3 PHONE UNSUPPORTED YET] | ~mr_Ten$ion~ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 02-20-2010 09:40 |
Nokia 5130 SP data possible to repair[SL3 PHONE UNSUPPORTED YET] | gsm5378 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-20-2010 09:38 |
