Old 03-05-2010, 10:13   #1 (permalink)
Member: 591222
Thanks Meter: 4
Smile 5310 SUPERDONGLE_KEY invalid![SOLVED BY USER]
hi
plz help
Phone Type: RM-303 (Nokia 5310 XpressMusic)
SW Version: V 09.42 07-11-08 RM-303 (c) Nokia
Imei plain: 35865301702705-7
Product Code: 0548081
Language Pack:
- not available.
SIMLOCK seems to be valid
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358653017027057
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
regard
Old 03-05-2010, 11:01   #2 (permalink)
Member: 555290
Originally Posted by TECNO_CARE View Post
hi
plz help
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
regard
easy brother........................................... .............:confus ed:
Old 03-05-2010, 11:05   #3 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
1.repair sd
2.super sd auth
3.write 1,309 pm
Old 03-05-2010, 11:08   #4 (permalink)
Member: 711498
Thanks Meter: 72
i think server is down
Old 03-05-2010, 12:23   #5 (permalink)
Member: 237628
Sonork: 100.1668254
Thanks Meter: 140
THIS IS RIGHT WAY I AM TESTED
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
Old 03-05-2010, 13:00   #6 (permalink)
Member: 591222
Thanks Meter: 4
problem solve
solve after click sd repair
thanks
The Following User Says Thank You to TECNO_CARE For This Useful Post:
how can solve contect service 3110c[SOLVED by USER] Abidqadeer MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 03-06-2010 15:34
MX Software Freezing[SOLVED by USER] curtisbcm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-04-2010 06:19
help..mx key show : ERROR=Invalid password.[SOLVED by USER] xiong897 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-01-2010 06:57
Nokia 7310c[SOLVED by USER] gerdzio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-27-2010 00:35
6300 SUPERDONGLE_KEY invalid[SOLVED] bilm25 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-20-2010 20:33
Page generated in 0.16452 seconds with 9 queries
