02-18-2010, 08:52 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1040045 Status: Offline Thanks Meter: 18 | 5610 contact services(ANSWERED) MCU SW version: V 09.40 07-11-08 RM-242 (c) Nokia HW version: 1000 RFIC version: 17141714 DSP version: ICPR71_08w30 LCD version: SHARP PPM version: V 09.40 07-11-08 RM-242 (c) Nokia W Retu version: 15 Tahvo version: 22 Content Pack version: Content: w V 09.40 07-11-08 RM-242 (c) Nokia Product Info: Production serial number: CEJ591907 Product code: 0552211 Module code: 0203378 Basic production code: 0515121 Long production SN: 0 Serial Numbers: IMEI plain: 358652012113813 IMEI spare to net: 3A 85 56 02 21 11 83 01 IMEI SV to net: 33 85 56 02 21 11 83 51 F8 Other Info: Model : Nokia 5610d-1 (Music Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA IV/WCDMA V BSI: 4.5 KOhm SIMLOCK_DATA corrupted! i written modifyed pm but 1 and 309 not writting please help |
02-18-2010, 08:54 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: VIZAG,A.P,๑۩INDIA&
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | bro do the repair-sd after write pm with super sd auth .mark only 1,309 then write your problem solved |
The Following User Says Thank You to laxman kumar For This Useful Post: |
02-18-2010, 08:55 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | post here scan and bus check log with mx-key here |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
02-18-2010, 09:21 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Proud To Be A Muslim Age: 39
Member: 434968 Status: Offline Sonork: 100.1590883 Thanks Meter: 580 | Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! ....cheak here log .... |
The Following User Says Thank You to diljan_07 For This Useful Post: |
02-18-2010, 09:36 | #6 (permalink) |
Member: 1040045 Status: Offline Thanks Meter: 18 | Connecting to server ...OK Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 122.183.211.1 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-18-2010, 09:49 | #7 (permalink) | |
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | Quote:
post your fbus cheak log file | |
02-19-2010, 07:55 | #8 (permalink) |
Member: 1040045 Status: Offline Thanks Meter: 18 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F000115E0F50154AEF1EB85E9136234F209E94A ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB Original Imei: 35865201211381 Original Product code: 0552249 Bluetooth ID: 001E3A6E01A5 Phone Type: RM-242 (Nokia 5610d-1) SW Version: V 09.40 07-11-08 RM-242 (c) Nokia Imei plain: 35865201211381-3 Product Code: 0552249 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed TimeStamp: 2008-07-18T11:42:57Z SW Version: 08.30 Variant Version: 010 ProductProfile: RM242_0552249_08.30_010.spr Simlock: 0552249_simlock.bin SIMLOCK_DATA corrupted! |
02-19-2010, 08:00 | #9 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: Split / Zagreb, Age: 15
Member: 1212935 Status: Offline Sonork: cylone team Thanks Meter: 122 | Quote:
try this method,, http://forum.gsmhosting.com/vbb/show...5&postcount=20 regards, | |
The Following User Says Thank You to Cyclone Team<3 For This Useful Post: |
02-19-2010, 08:01 | #10 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | FIRST MAKE SIMLOCK REPAIR WITH SIMLOCK RPL THEN MAKE SDREPAIR THEN SUPER PM AUTH WRITE PM WITHOUT 308 WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
02-19-2010, 08:26 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
Repair SD than sd pm auth than pm thanx | |
The Following User Says Thank You to hasnain For This Useful Post: |
02-21-2010, 14:59 | #13 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
hi all here is guid of sl1 and sl2 soper dongel sl1 and old bb5 ( bb5>>sevice>>imei&securty>>imei rebuild>>npc back up>>reset npc>>repair sd>>write rpl>> now go to simlock>>repair splock now your fone is ok here is sl2 ((bb5>>sevice>>imei&securty>>imei rebold>>baup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik injoy your fone now | |
"help contact service" | neb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 09-10-2011 07:40 |
contact service due to unlocking | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-11-2000 21:42 |
Nokia 6150 "Contact Service" | Rui | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-11-2000 03:16 |
" CONTACT SERVICE " on 5110 v 5.29 because of unlocking | Razvan Chirica | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-08-2000 08:29 |
help! contact service 5.28 5110! | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-23-2000 15:43 |
