Old 01-28-2010, 07:13   #1 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
5800 contact retailer security test failed sx4 not sucess. why??????
here is the log--------
hone Type: RM-356 (Nokia 5800 XpressMusic)
SW Version: V ICPR72_09w20.8 09-07-09 RM-356 (c) Nokia
Imei plain: 35824703289096-9
Product Code: 0593493
ApeCoreSw: V 31.0.008
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358247032890969
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 115.127.15.3
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
whats the reason??
Old 01-28-2010, 07:35   #2 (permalink)
Member: 762819
Thanks Meter: 232
Dear! You should write PM309 field, If not done then downgrade ur phone and then flash ur problem will be solved
Old 01-28-2010, 08:08   #3 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
are you sure?????????????//
Old 01-28-2010, 08:28   #4 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
dont downgrade your phone it can be kill it just write 309 pm with sx4 and say all is well
Old 01-28-2010, 08:54   #5 (permalink)
Member: 889262
Thanks Meter: 3
That's the problem...., It's can't do SX4
Old 01-28-2010, 10:23   #6 (permalink)
a38
Member: 1027249
Thanks Meter: 24
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
whats the reason??
seen as being repaired: http://www.4shared.com/file/19203979...st_failed.html
Need a PM New and good
that does not have 308 or 120
NPC resets will not have to use SX4 server
and then restore your certificate
Old 01-28-2010, 10:26   #7 (permalink)
a38
Member: 1027249
Thanks Meter: 24
Old 01-28-2010, 12:12   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if phone already fix (superdongle) by other tools ( UB/MT/GENIE ) u can't use SX-4 MXKEY server
each tools have "unique" ways to repair that .
br,
Old 01-28-2010, 12:32   #9 (permalink)
Member: 856803
Sonork: 100.1592550
Thanks Meter: 151
Arrow
br,
SIMLOCK_TEST passed
Here superdongle key is valid then why it shows
Like this
Old 01-28-2010, 12:37   #10 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
bro try with UB pmauth many time test and work
Old 01-28-2010, 12:37   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
hi.
have u read my post ?
yes u have valid one,but already bypass fix by other tools,
so can't make sx-4 with our server.cas that have "unique" way.
ex:
if u have repair by MT so can't use SX-4 UB serve.
and other.
repair by MT,SX-4 by MT server to. not other.
br,
Old 01-28-2010, 12:53   #12 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
hi.
ex:
and other.
br,
if i again damage sd ,than its possible by mx-key???
Old 01-28-2010, 13:01   #13 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,514
try with jaf with crt bypass means sx4 bypass
Old 01-28-2010, 13:08   #14 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
No SX4 Card found.
whats the reason??
B4 do any job keep pm and RPl
then try to write pm with mt box using sx4 .
Old 01-28-2010, 13:09   #15 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
i try with mt-box also.but not success
3110c - Contact Service - Security Test Failed! [Shadab_M] Cyclonebox 4 03-16-2010 07:24
N76 contact retailer/sec test failed...error in writing PM a professor linux Cyclonebox 10 03-07-2010 08:46
HELP MX TEAM NOKIA 5800 RM 428 security test failed!!!! michael garcia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-08-2010 02:22
my 3110c contact service security test failed.........please help me(with video File) swechacnu MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 10-12-2009 12:22
Page generated in 0.33296 seconds with 10 queries
