02-08-2010, 05:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: DUBAI, UAE
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | 5800 successfully sd repair with new update in mxkey Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 357988030****** Product Code: 0591106 ApeCoreSw: V 21.0.025 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3579880309***** Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-08-2010, 05:15 | #2 (permalink) | |
Junior Member Join Date: Apr 2008 Location: Mataram Lombok Indonesia
Member: 761225 Status: Offline Sonork: adryfia Thanks Meter: 0 | Quote:
02-08-2010, 05:32 | #5 (permalink) |
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | steps are 1. repair the simlock tick( mark simlock rpl ) . 2. next click the sd repair button. 3. go to pm tab and sd auth click it. 4. and load from file pm full pm from files and write 1 and 309 only this tick and write pm file that it u will get the phone and enjoy if any problem connect with in yahoo messange. |
The Following User Says Thank You to azad4u For This Useful Post: |
02-08-2010, 06:32 | #7 (permalink) | |
Freak Poster Join Date: May 2009 Location: Bangladesh Age: 44
Member: 1025487 Status: Offline Thanks Meter: 64 | Quote:
yse sir u stap is good way i know that but i will try 5130 is sd problem use this option & this phone is made is contact service. what i do it.........plz help | |
7210c successfully sd repair with new update in mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-12-2010 10:41 |
100% ok SD Repair with Mxkey | ashik123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-06-2010 10:20 |
n96 successfully sd repair by mxkey | azad4u | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-03-2010 15:24 |
E1120 Successfully Direct Unlock with New Update Ver 11.00 | kashi4gul | UST Pro II | 3 | 12-19-2009 12:41 |
N95 (8-gb) Successfully Unlocked with new Update in few seconds | Ja\/\/aD | Universalbox | 4 | 04-06-2009 16:06 |
