02-18-2010, 06:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: DUBAI, UAE
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | 5800 unlocking soluition for Version 30 and 31 5800 unlocking soluition for Version 30 and 31 because it will say it was sl3 that time u want do it i was downgrade into version 21 i have use jaf box . after downgrade have been finish mobile was restarting include nokia only do not fear about that after that u go to mxkey and scan the mobile Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 3579880388****** Product Code: 0591106 ApeCoreSw: V 21.0.025 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! after that u go to imiei rebulid tab and selected repair sd after that here is logs before doing REPAIR SD U NEED CHECK THE NET CONNECTION IS OK Product: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia ApeCoreSw: V 21.0.025 Using cached productData[1B6001136CA38B52C915A64E56C326280D2EC252] ... Calculating SUPERDONGLE using security server ... Completed in 29.562 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-356_357988038868738_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK Product: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia ApeCoreSw: V 21.0.025 Using cached productData[1B6001136CA38B52C915A64E56C326280D2EC252] ... Calculating SUPERDONGLE using security server ... Completed in 29.562 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-356_357988038868738_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK after that u go to pm tab and click SUPER SD Auth click here is the logs Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12183(16-02-2010) Product: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia ApeCoreSw: V 21.0.025 Using cached productData[1B6001136CA38B52C915A64E56C326280D2EC252] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! after that go to load from file and selected the full pm file only selected the 01 pm file and 309 pm only u will get tick only most important here is logs for it Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 5.250 s after that ok fine now enjoy and scan u will get this logs Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 35798803886873-8 Product Code: 0591106 ApeCoreSw: V 21.0.025 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357988038868738 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia Imei plain: 35798803886873-8 Product Code: 0591106 ApeCoreSw: V 21.0.025 Language Pack: that ok i was unlocked 5 set from 30 version thanks to mxkey for nice update i have first downgrade to version21 and after u will do sd repair from mxkey thanks to all if u have any problem buzz me in yahoo mail i will help u for ever |
The Following 2 Users Say Thank You to azad4u For This Useful Post: |
02-18-2010, 17:11 | #3 (permalink) |
Member: 497374 Status: Offline Sonork: 1587252:AZAD Thanks Meter: 93 | i will give the website u will download it from it http://support.saigonmobile.vn/ this website register it u can download all the things ok brother thanks for giving me comments |
Nokia 5800 XM RM-356 firmware 30 and 31.0.101 - service manual | pitone02 | Nokia Base Band 5 ( BB-5 ) | 1 | 11-06-2009 23:03 |
sl2 full support for version avaibles and comonīs 6120 ok.. | residentdenuevo | Cyclonebox | 3 | 06-11-2009 07:49 |
need unlock code for gx 30 | virasat_husain | Sharp | 3 | 05-29-2006 11:40 |
Unlock code for TSM 30 | emilio | Phone Unlocking Codes & Maps | 2 | 05-28-2004 16:47 |
need to unlock LG usa version 4010 and 4050 | WIDE | LG | 3 | 04-02-2004 06:50 |
