Old 03-04-2010, 23:24   #1 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
Question 5800 what happend please[SOLVED]
Imei net: 355225031722212
Version: SIMLOCK SERVER
Provider: Movistar (DCT4), Country: Spain
Counter: 0/3, 0/10
CONFIG_DATA: 2140700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F
BLOCK 2: 1=LOCKED (MCC+MNC): 21407F, DATA=21407F
BLOCK 3: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F
BLOCK 4: 1=LOCKED (MCC+MNC): 21402F, DATA=21402F
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Product: V ICPR72_08w47 24-11-08 RM-356 (c) Nokia
ApeCoreSw: V 11.0.008
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Calculating SIMLOCK using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 11.766 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-356_355225031722212_SIM.RPL"
Updating SIMLOCK...error 0x1
Reading Simlock info ...
Counter: 0/3, 0/10
Old 03-04-2010, 23:27   #2 (permalink)
Member: 721704
Thanks Meter: 4
re
search forum, already posted. keyword error 0x1.
Old 03-05-2010, 02:00   #3 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
SIMLOCK_DATA corrupted!
Product: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia
ApeCoreSw: V 20.0.012
Completed in 11.984 s
now phone only vibrate check this please
Phone Type: RM-356 (Nokia 5800 XpressMusic)
SW Version: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia
Imei plain: 35522503172221-2
Product Code: 0575956
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
now bus check
look this
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1F8000069D7A0052E8B9C45970F2AE8B6713D31E
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61
Original Imei: 35522503172221
Original Product code: 0575956
Bluetooth ID: 0025CF9DC501
WLAN ID: 0025CF9E6141
Language Pack:
- not available.
SIMLOCK invalid!
Old 03-05-2010, 02:03   #4 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
i flash phone to 20.0.012 but phone only vibrate need from your help
i was working with zulea 2.1 but nothing im traite to put backup but still same
backup dont work helpme please
Old 03-05-2010, 02:25   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
do you have all back up section usually before you do that make first back all section to safe your phone this is the very important way of your mobile phone this is a new version flash again the original firmware then if will be back again used make simlock rpl then unlock by code but identify first if this is sl3 or sl20 type if sl20 or sl2 is supported to unlock except pa pure sl3 .
with best regards;
lilong lee
The Following User Says Thank You to lilong_lee For This Useful Post:
Old 03-05-2010, 04:39   #6 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
ok now i flash phone with original product now what do i have to do need help please check this
Restoring RF/BB DATA from backup ...
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0575956)... OK
Updating PSN (MMJ855570)... OK
Updating HWID (1101)... OK
Updating SIMLOCK...error 0x7
Trying to update SUPERDONGLE_KEY ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
SW Version: V ICPR72_09w06.2 03-03-09 RM-356 (c) Nokia
ApeCoreSw: V 21.0.025
Language Pack:
- not available.
SIMLOCK invalid!
TimeStamp: 2009-05-28T11:19:47+00:00
SW Version: 21.0.025
Variant Version: 002
ProductProfile: RM356_0575956_21.0.025_002.spr
Simlock: Movistar_Spain.bin
Old 03-05-2010, 09:14   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
1. backup RPL(just in case).
2. erase EEPROM.
3. Repair SD
4. Full Factory
5. SUPER SD Auth + Write PM1,309
details info
1.Service -> Imei & Security -> IMEI Rebuilt
2.Flash -> advance -> Get address
untick safe erase.
tick eeprom area only
DO "ERASE"
3.repair SUPERDONGLE
4.Full Factory
5."SUPER SD AUTH"
write PM [1] and [309]
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-05-2010, 20:09   #8 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
need a pm please i dont have one please
Old 03-06-2010, 03:32   #9 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
tanks its ready tanks mxkey team
What happend to my BOX @.:hack3r2k:. [SOLVED] srkhan FuriousGold 8 08-16-2009 11:00
5800 problem, help me please - SOLVED kalasniko1 Cyclonebox 3 07-30-2009 10:33
WHAT HAPPEND with REAL SUPPORT FURIOUS???!!!! SOLVED humbedj FuriousGold 8 03-27-2009 01:25
what happend team you cant solve my problem let me know denisirias Infinity-Box 8 07-10-2008 22:54
Server problem what happend ???LOGGING IN, PLEASE WAIT... ZetMen JAFWM 31 06-29-2006 08:48
Page generated in 0.40111 seconds with 8 queries
