09-27-2010, 10:56 | #1 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: cambodia
Member: 578236 Status: Offline Thanks Meter: 31 | 5800d only one vibration and nothing Quote:
Hi all friends here I met the problem similar to the above and i try to search in the forum but no body solved it My one at the first time is dead after flashing with ver.30 or 50. the phne became ok (But) the phone can power on and can see the screen for around 3 minute untile it lock the keypad then i can not seen any thing in the screen(black) then i press the side key many time or press the power on key 1 or 2 time that can see the screen during i see the screen i can play any thing all in the menu after it the LCD light off the difficult again if i take the battery out and put it back and power on it will be ok after it the LCD light off the difficult again I try to flash any time the stile the same what is the problem | |
09-27-2010, 11:04 | #2 (permalink) |
Member: 578236 Status: Offline Thanks Meter: 31 | After 2 day i can not see the LCD i try many way , the LCD became line with many color like Bad LCD I have changed LCD IC (Z245) near the socket but stile the same i try many time to open just one vibrate and the phone stile on can be call in and can be talk with black screen but if i take battery out and put in back then power on , i can see the lcd and can play any thing , no problem (if i don't rest of pressing) so i feel the lcd bad , but why after new open we can see the LCD very long time if keep pressing the key The program feel no problem any body solve the similar problem please help me |
09-27-2010, 11:24 | #4 (permalink) |
Member: 578236 Status: Offline Thanks Meter: 31 | this is the lcd schematic i feel that some thing wrong with the software because the lcd very clear at the first open and keep pressing i have change the lcd , because at the remote area difficult to test it but after this phone can not be solved then i gave to the owner with the problem after 1 week they hand me back with extra problem the phone just only one vibate then nothing can be use and the phone off can not be call in press power on again it will be the same the battery already changed open with power supply with ~3.7v or ~4.5v it stile the same but if i flash it with usb then the phone on it self and can see the lcd very clear with test mode letter if i take it out from the battery , just only one vibate i flash with fbus also the same with usb i already clean many time now the last problem is one vibrate only after one vibration can not be call in, phone is off after flashing phone is on and lcd can see clearly How and what is the problem??????????????? sorry to let you read too many text thanks in advance |
09-27-2010, 11:34 | #5 (permalink) |
Member: 578236 Status: Offline Thanks Meter: 31 | OH sorry forgot to post the log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0C9001190C7200522DC0481326F959D7A363B853 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0040 - 0040 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 Original Imei: 35418202393493 Original Product code: 0559676 Bluetooth ID: 00240497E017 WLAN ID: 002404982E37 Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia Imei plain: 35418202393493-6 Product Code: 0559676 ApeCoreSw: V 20.0.012 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354182023934936 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF info Version Info: MCU SW version: V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia HW version: 1101 RFIC version: 17141715 DSP version: ICPR72_09w02 APE SW Core version: V 20.0.012 APE Variant version: V 20.0.012V 20.0.012 V 51.0.006 APE Test version: 2008wk50v0.012 Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 WLAN Id: : 00 37 2E 98 04 24 Product Info: Production serial number: C7B498653 Product code: 0559676 Basic production code: 0552692 Long production SN: 0 Serial Numbers: IMEI plain: 354182023934936 IMEI spare to net: 3A 45 81 02 32 39 94 03 IMEI SV to net: 33 45 81 02 32 39 94 43 F0 NCK: Other Info: Model : Nokia 5800 XpressMusic (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII BSI: 5.0 KOhm Imei net: 354182023934936 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
09-27-2010, 12:30 | #6 (permalink) | |
Registered User Join Date: Nov 2009 Location: RSA
Member: 1166923 Status: Offline Thanks Meter: 77 | Quote:
Hi, Try this & maybe can solve your problem. http://forum.gsmhosting.com/vbb/f299...roblem-921662/ with best regards | |
The Following User Says Thank You to AOA For This Useful Post: |
09-27-2010, 14:21 | #7 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: dhaka,bangladesh
Member: 649043 Status: Offline Thanks Meter: 18 | Quote:
try to re hote combo ur probleam will solve | |
The Following User Says Thank You to delwar_us For This Useful Post: |
09-27-2010, 15:42 | #8 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Saudi arabia Age: 38
Member: 442126 Status: Offline Thanks Meter: 24 | brother if u can call an cal back with black lcd ,check ur ligtsensor...jst change the sencer then check... |
The Following User Says Thank You to kmi2 For This Useful Post: |
09-27-2010, 20:03 | #9 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi! Flash it with the original version of the firmware(according to product code: 0559676) download the firmware from navifirm and then flash with Jaf in dead usb mode and post the results.... Last edited by Shensohau; 09-27-2010 at 20:09. |
The Following User Says Thank You to Shensohau For This Useful Post: |
09-28-2010, 01:13 | #10 (permalink) | |
Member: 578236 Status: Offline Thanks Meter: 31 | Quote:
first can be that but now only one vibrate and finish but can be check and info well | |
09-28-2010, 01:14 | #11 (permalink) | |
OK, i will play with software again to day , before playing with any hardware thanks | |
09-28-2010, 01:55 | #12 (permalink) | |
OK, Now i use JAF to check and info and sorry to Mxkey team and manole to post about JAF just only check and info seem to be ok with the software so can you see and consider what problem JAF check JAF version 1.98.65 Detected PKEY: 900048BA P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B4, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Booting phone... Error sync the phone... Booting phone... Error sync the phone... Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 0C9001190C7200522DC0481326F959D7A363B853 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 09.30.00 -> Revision: 0200 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00000400 <=> Flash ID not in database CMT Flash Data: NOT AVAILABLE C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_XSR15_alg.fg... ........Sending CMT HASH for PASUBTOC .........................Sending CMT HASH for ALG ...........................Done! CMT Loader Ready Done! Restarting phone...Done! info FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V ICPR72_10w21.3 23-06-10 RM-356 (c) Nokia HW version: 1101 PCI version: RFIC version: DSP version: APE SW Core version: V 51.0.006 APE Variant version: V 51.0.006V 51.0.006 V 51.0.006 APE Test version: eno_version Retu version: 16 Tahvo version: 22 APE HW version: 256 APE ADSP SW version: 256 Production serial number: C7B498653 Product code: 0559676 Module code: Basic production code: 0552692 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 354182023934936 IMEI spare to net: 3A 45 81 02 32 39 94 03 IMEI SV to net: 33 45 81 02 32 39 94 63 F8 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-356.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0559676 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\ Searching for default location of ini... Checking path: \Products\RM-356\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-356\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! | |
09-28-2010, 04:47 | #15 (permalink) | |
but the check and info stile ok like i post do you don't know how to flash? 1 Just use Mxkey 2 download any full flash file version match your prefer 3 install it 4 then you can select the right model 5 select to right version from market of mxkey 6 then the file flash will appear automatically 7 safe flash(for back up RPL during flashing) 8 press flash 9 just wait untile every thing finish that all | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
