05-28-2010, 14:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | run MXkey program 1.Service 2.Imei&Security 3.Online logger 4. mark DCT4 imei after all press DO SELECTED JOB you will receive new imei for your phone enjoy bro |
05-28-2010, 18:37 | #6 (permalink) |
Crazy Poster Join Date: Apr 2009 Location: Ipatinga, Brazil Age: 32
Member: 1005539 Status: Offline Thanks Meter: 8 | Try this procedure ... 1)...services 2)...Imei & Security 3)...Online logger 4)...Dct4 imei 5)...Do select 6)...Reset 7)...write RPL... press thx button |
06-16-2010, 13:29 | #7 (permalink) |
Freak Poster Join Date: May 2005 Location: The_Mobile_Pakistan
Member: 145399 Status: Offline Thanks Meter: 26 | trying to write rpl but failed. here is log. ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00836682:2984DA60 ASIC type: 2 UEM Imei: 35xxxxxxxxxxxxx SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35xxxxxxxxxxx.RPL " ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00836682:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone Type: RM-166 (Nokia 6070) SW Version: V 03.20 18-05-06 RM-166 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 35xxxxxxxxxxxx Product Code: 0532088 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: F Language Pack: English,German,Hebrew,Arabic,Russian Imei plain is invalid !!! Failed to read SP data pls.help. |
01-11-2011, 20:28 | #8 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | And I can't fix imei plain in 6070 RM-166? Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00874177:2984DA60 ASIC type: 2 UEM Imei: 35xxxxxxxxxxxx Flash Imei: 35xxxxxxxxxxxx MasterCode: 5155777403 RPL saved to "C:\mobileEx\3.4\data\backup\35xxxxxxxxxxxx_BACK.rpl" Phone Type: RM-166 (Nokia 6070) SW Version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 35xxxxxxxxxxxx Cellular System: GSM ASIC ID: 0x3160, type: 2 Ppm Id: I Language Pack: English,Portuguese,Spanish,French Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! Code: ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00874177:2984DA60 Trying to find patch position ...Ok, found in 9.312 s Not supported firmware. Error while processing command ! Code: Updating SIMLOCK ...Error 2 Updating SIMLOCK ...Error 2 PhoneType:RM-166 SwVersion: V 04.22 24-05-07 RM-166 (c) Nokia. MCU file: rm166__04.220 Trying to find patch position ...OK, case id: 4 New Imei: 35xxxxxxxxxxxx ASIC ID: 0x3160 [UPP_8M ver: 6.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00874177:F4E0DA60 Area [01000000-0101FFFF] erased in 1.172 s Area [010A0000-010BFFFF] erased in 1.188 s Area [010C0000-010DFFFF] erased in 1.172 s Programming ... Programming completed. Phone not responding ! I try repair by service-> imei & security-> Online logger->ticked DCT4 IMEI & do selected job, pass without error but without success: Code: Phone Type: RM-166 (Nokia 6070) SW Version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: ??????????????-? Imei OTP: 35xxxxxxxxxxxx Cellular System: GSM ASIC ID: 0x3160, type: 2 Ppm Id: I Language Pack: English,Portuguese,Spanish,French Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 0000000000000000 SIMLOCK_DATA corrupted! Need solution. |
01-13-2011, 18:25 | #10 (permalink) | |
Member: 219015 Status: Offline Thanks Meter: 42 | Quote:
I try repair by service-> imei & security-> Online logger->ticked DCT4 IMEI & do selected job, pass without error but without success: this solution-without success. | |
01-13-2011, 21:03 | #11 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | why edited dct4 imei on logs. i can NOT see and check your OTP is good or not. - reset data1 - full erase by get address, untick safe erase. - full flash - repeat imei rebuild...blablabla.. BR |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
