02-13-2010, 12:58 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | 6070 SIMLOCK_DATA corrupted! Help ! SW Version: V 04.22 24-05-07 RM-166 (c) Nokia. Imei plain: 35362801223481-2 Imei OTP: 35362801223481 Product Code: 0532103 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: G Language Pack: English,French,German,Spanish,Arabic Imei net: 35362801223481 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000002 SIMLOCK_DATA corrupted! Already loose 50 credis !!! " ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CB2F34:2984DA60ASIC type: 2UEM Imei: 35362801223481Connecting to server ...OK, Login ... Hello C0805AC3, you have 950 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35362801223481.RP L" ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CB2F34:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. |
02-13-2010, 13:07 | #2 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | When trying to UNLOCK the Phone : Imei net: 35362801223481 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000002 SIMLOCK_DATA corrupted! Updating SIMLOCK ...Error 2 PhoneType:RM-166 SwVersion: V 04.22 24-05-07 RM-166 (c) Nokia. MCU file: rm166__04.220 Trying to find patch position ...OK, case id: 4 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CB2F34:F4E0DA60 Area [01000000-0101FFFF] erased in 0.828 s Area [010A0000-010BFFFF] erased in 0.859 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x01 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00CB2F34:F4E0DA60 Area [01000000-0101FFFF] erased in 0.875 s Area [010A0000-010BFFFF] erased in 0.859 s Programming ... Programming completed. |
02-13-2010, 13:11 | #3 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 439 | Already written PM file : Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 86 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 2 bytes written. - Key: 6, size 86 bytes written. - Key: 8, size 110 bytes written. - Key: 11, size 8 bytes written. - Key: 12, size 2 bytes written. - Key: 13, size 86 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. Section: 2 - Key: 0, size 356 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 24 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 12, size 50 bytes written. - Key: 13, size 1 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 60 bytes written. - Key: 19, size 4 bytes written. Section: 7 - Key: 0, size 4 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 2 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 7, size 8 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 2 bytes written. - Key: 13, size 16 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 2 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 4 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 4 bytes written. - Key: 58, size 4 bytes written. - Key: 59, size 4 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 16 bytes written. - Key: 62, size 4 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 4 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. Section: 33 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 36 bytes written. - Key: 14, size 36 bytes written. - Key: 15, size 36 bytes written. - Key: 16, size 36 bytes written. - Key: 17, size 36 bytes written. - Key: 18, size 36 bytes written. - Key: 19, size 36 bytes written. - Key: 20, size 36 bytes written. - Key: 21, size 36 bytes written. - Key: 22, size 36 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. - Key: 27, size 40 bytes written. - Key: 28, size 40 bytes written. - Key: 29, size 40 bytes written. - Key: 30, size 40 bytes written. Section: 44 - Key: 0, size 2020 bytes written. - Key: 1, size 420 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. Section: 46 - Key: 0, size 8 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 76 bytes written. Section: 56 - Key: 0, size 4 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 40 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 40 bytes written. - Key: 5, size 20 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 2 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 43, size 63 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 2 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 4 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 4 bytes written. - Key: 76, size 4 bytes written. - Key: 77, size 4 bytes written. - Key: 79, size 4 bytes written. - Key: 80, size 4 bytes written. - Key: 81, size 4 bytes written. - Key: 83, size 4 bytes written. - Key: 84, size 1800 bytes written. - Key: 85, size 60 bytes written. - Key: 86, size 4800 bytes written. - Key: 87, size 300 bytes written. - Key: 88, size 50 bytes written. - Key: 89, size 6 bytes written. - Key: 90, size 4 bytes written. - Key: 94, size 64 bytes written. - Key: 95, size 64 bytes written. - Key: 96, size 15080 bytes written. - Key: 101, size 3 bytes written. - Key: 102, size 3 bytes written. - Key: 103, size 3 bytes written. - Key: 104, size 3 bytes written. Section: 67 - Key: 0, size 1848 bytes written. Section: 76 - Key: 0, size 532 bytes written. Section: 83 - Key: 0, size 811 bytes written. - Key: 1, size 791 bytes written. - Key: 2, size 1054 bytes written. - Key: 3, size 774 bytes written. - Key: 4, size 576 bytes written. - Key: 5, size 850 bytes written. - Key: 6, size 940 bytes written. - Key: 7, size 910 bytes written. Section: 84 - Key: 0, size 3 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 93 bytes written. - Key: 3, size 147 bytes written. - Key: 4, size 141 bytes written. - Key: 5, size 133 bytes written. - Key: 6, size 113 bytes written. - Key: 7, size 125 bytes written. - Key: 8, size 137 bytes written. - Key: 9, size 113 bytes written. - Key: 10, size 121 bytes written. - Key: 11, size 125 bytes written. - Key: 12, size 149 bytes written. - Key: 13, size 139 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 94 - Key: 0, size 40 bytes written. Section: 95 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 110 - Key: 0, size 6 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 36 bytes written. - Key: 14, size 36 bytes written. - Key: 15, size 36 bytes written. - Key: 16, size 36 bytes written. - Key: 17, size 36 bytes written. - Key: 18, size 36 bytes written. - Key: 19, size 36 bytes written. - Key: 20, size 36 bytes written. - Key: 21, size 36 bytes written. - Key: 22, size 36 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. - Key: 27, size 40 bytes written. - Key: 28, size 40 bytes written. - Key: 29, size 40 bytes written. - Key: 30, size 40 bytes written. - Key: 31, size 40 bytes written. - Key: 32, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 9 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 15, size 1 bytes written. Section: 118 - Key: 0, size 1 bytes written. - 120 skipped Section: 127 - Key: 1, size 614 bytes written. - Key: 2, size 614 bytes written. - Key: 3, size 614 bytes written. - Key: 4, size 614 bytes written. - Key: 5, size 614 bytes written. - Key: 6, size 614 bytes written. - Key: 7, size 614 bytes written. - Key: 8, size 614 bytes written. - Key: 9, size 614 bytes written. - Key: 10, size 614 bytes written. - Key: 11, size 614 bytes written. - Key: 12, size 614 bytes written. - Key: 13, size 614 bytes written. - Key: 14, size 614 bytes written. - Key: 15, size 614 bytes written. - Key: 16, size 614 bytes written. - Key: 17, size 614 bytes written. - Key: 18, size 614 bytes written. - Key: 19, size 614 bytes written. - Key: 20, size 614 bytes written. - Key: 21, size 614 bytes written. - Key: 22, size 614 bytes written. - Key: 23, size 614 bytes written. - Key: 24, size 614 bytes written. - Key: 25, size 614 bytes written. - Key: 26, size 614 bytes written. - Key: 27, size 614 bytes written. - Key: 28, size 614 bytes written. - Key: 29, size 614 bytes written. - Key: 30, size 614 bytes written. - Key: 31, size 614 bytes written. - Key: 32, size 614 bytes written. - Key: 33, size 614 bytes written. - Key: 34, size 614 bytes written. - Key: 35, size 614 bytes written. - Key: 36, size 614 bytes written. - Key: 37, size 614 bytes written. - Key: 38, size 614 bytes written. - Key: 39, size 614 bytes written. - Key: 40, size 614 bytes written. - Key: 41, size 614 bytes written. - Key: 42, size 614 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 bytes written. Section: 182 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 183 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 184 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 185 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 186 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 187 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 4 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. Section: 200 - Key: 0, size 5 bytes written. Section: 206 - Key: 0, size 269 bytes written. - Key: 1, size 259 bytes written. - Key: 2, size 227 bytes written. - Key: 3, size 191 bytes written. - Key: 4, size 186 bytes written. - Key: 5, size 154 bytes written. - Key: 6, size 176 bytes written. - Key: 7, size 155 bytes written. Section: 208 - Key: 0, size 40 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 - Key: 0, size 1 bytes written. - Key: 1, size 6 bytes written. - Key: 2, size 6 bytes written. Section: 228 - Key: 1, size 4 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. Section: 238 - Key: 0, size 78 bytes written. - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 992 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 250 bytes written. - Key: 4, size 32 bytes written. Completed in 27.360 s |
6120c SIMLOCK_DATA corrupted! HELP | rushad22 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 11-21-2011 10:38 |
7210 SIMLOCK_DATA corrupted! Help | kaino147 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 26 | 10-01-2010 10:16 |
Nokia 6303: DEAD then flashed to life now... SIMLOCK_DATA Corrupted! - Help Please | ollyinto | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 04-02-2010 16:13 |
7210c SIMLOCK_DATA corrupted! Help me Mxkey Team[SOLVED] | R@ZIB-BD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 44 | 03-30-2010 09:26 |
