04-12-2010, 12:24 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594019 Status: Offline Thanks Meter: 46 | 6110 contact retailer How to solve this plz?? I'm newer with MX key Phone Type: RM-122 (Nokia 6110) SW Version: V 06.01 02-09-08 RM-122 (c) Nokia Imei plain: 35766601314146-7 Product Code: 0546017 ApeCoreSw: 06.01 ApeVariant: Vr EURO1 01-12-06 RM-122 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! Imei net: 357666013141467 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-12-2010, 15:37 | #2 (permalink) |
Product Supporter Join Date: Oct 2009 Location: Mumbai. Great India
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | use sx4 and write pm 1, and 309 filed your problem will be solved |
The Following 2 Users Say Thank You to king.of.gsm For This Useful Post: |
04-12-2010, 15:58 | #4 (permalink) |
Member: 594019 Status: Offline Thanks Meter: 46 | I can't use SX4 because this No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.104.74.80 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request It pass just with SUPER SD AUTH like this Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7945(11-04-2010), 1.0.0.12651(18-03-2010) Product: V 06.01 02-09-08 RM-122 (c) Nokia ApeCoreSw: 06.01 Using cached productData[19F0010A196E005881252475F563D0889622F2F3] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! |
04-12-2010, 16:03 | #6 (permalink) | |
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | Quote:
click on super SD Auth and write pm problem solved | |
04-12-2010, 16:21 | #7 (permalink) |
Member: 594019 Status: Offline Thanks Meter: 46 | Same problem bro Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7945(11-04-2010), 1.0.0.12651(18-03-2010) Product: V 06.01 02-09-08 RM-122 (c) Nokia ApeCoreSw: 06.01 Using cached productData[19F0010A196E005881252475F563D0889622F2F3] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 15, size 4 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 27, size 4 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 44, size 182 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 0.907 s And when I try write RPL without NPC, It's result RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 19F0010A196E005881252475F563D0889622F2F3 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 1A6CB332579705F9ED945C0AD7530A7055C2BCE8 NPC verified Ok. Updating CMT CCC ...failed, Result: 0640000000117200 Certificate programmed successfully ! Phone Type: RM-122 (Nokia 6110) SW Version: V 06.01 02-09-08 RM-122 (c) Nokia Imei plain: 35766601314146-7 Product Code: 0552058 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! Imei net: 357666013141467 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-12-2010, 16:25 | #8 (permalink) |
Member: 594019 Status: Offline Thanks Meter: 46 | And This with RECOVER CERT: RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 19F0010A196E005881252475F563D0889622F2F3 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 1A6CB332579705F9ED945C0AD7530A7055C2BCE8 Reading RAP NPC (0x168 bytes) Begin Certificate Request ... Connecting to server ...OK, Login ... Query done with status: OK Updating PRODUCTCODE (0552058)... OK Updating CMLA_KEY...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 19F0010A196E005881252475F563D0889622F2F3 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 1A6CB332579705F9ED945C0AD7530A7055C2BCE8 Updating CMT NPC ...OK Updating CMT CCC ...failed, Result: 0640000000117200 Certificate programmed successfully ! |
04-12-2010, 16:29 | #10 (permalink) |
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | 1st: overwrite this rpl if your problem not solved then upload your rpl backup here here is link: http://www.4shared.com/file/VoX7qhuW..._by_sabir.html |
04-12-2010, 16:36 | #12 (permalink) | |
Member: 594019 Status: Offline Thanks Meter: 46 | Not solved sir RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 19F0010A196E005881252475F563D0889622F2F3 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 1A6CB332579705F9ED945C0AD7530A7055C2BCE8 NPC verified Ok. Updating CMT CCC ...failed, Result: 0640000000117200 Certificate programmed successfully ! Phone Type: RM-122 (Nokia 6110) SW Version: V 06.01 02-09-08 RM-122 (c) Nokia Imei plain: 35766601314146-7 Product Code: 0552058 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! Imei net: 357666013141467 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF This is RPL Backup Quote:
04-12-2010, 16:42 | #13 (permalink) |
Member: 1135304 Status: Offline Sonork: 100.1592050 QQ:3549168141 Thanks Meter: 4,071 | HWC_DATA missing write this rpl Code: [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0552058 PSN=CRC916404 HWID=1527 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303535323035384300000000 NPC_DATA_2=0000000000000000000000008343E0942565474 713822500646F72420000000019F0010A196E0058 NPC_DATA_3=81252475F563D0889622F2F31A6CB332579705F 9ED945C0AD7530A7055C2BCE88BE2CEBEF0A364A7 NPC_DATA_4=C8E316D303607C0283542C62000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3375660631414176FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=A25860D61C00000000000000000000000000000 000000000000000000000000076AC584E25396F74 NPC_DATA_7=5CA455583C78F3DEF1BEACC84ECE27C4B59A3BE 530DC2723D81C0C0A251307635A3CE11E2493C062 NPC_DATA_8=408BFD38570DA86A1F29C214BCB8F256111D746 4113B5570046A5F98B15C8B108016540B422588FC NPC_DATA_9=417DEB41DD08756894259519904B81536328C84 82E395270D002447BFFDC35CEDC0AC4B3D58BB2EC CCC_DATA_1=4343434302004150010000009138E094B9EA6747410CB70011969900000074030100000000000000 CCC_DATA_2=000000000000000000000000E7378B588F6BBFD34D657B38B7A66AE443D810383035353838343943 CCC_DATA_3=24C4F6450000000000000000030000000F0000000100000000000000000000000000000000000000 CCC_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000 CCC_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000 CCC_DATA_6=0000000000000000000000000000000000000000000000009CADABEB29F1C1DE9A5422E84D85C722 CCC_DATA_7=99C577227E81BE425100B73314375BC8EEC9EE5BB2CA6484E04785163978AD4D419953803103CBB4 CCC_DATA_8=ECAFAA42DF145E4D82A881F16EE56709603A2C53EE8142FDBF751EF0CE4E0D77A8D51DB15B221ED3 CCC_DATA_9=DF38AD0ABE945066921155F923F5B0AB2EF49B2824AE67E1F94D75036B010DB20000000008020000 CCC_DATA_10=0400000004000000000200000400620000000989DB4022D8228B223C1FA99F3567A03D000000A118 CCC_DATA_11=4962657269616E2050656E696E73756C617C32303036513400000009DEBDAE98793DE04400F76A21 CCC_DATA_12=8FE7B1A100004A82184962657269616E2050656E696E73756C617C323030375132C515D65F189065 CCC_DATA_13=C2E45C9B5BB47882C44F9AA30669FC3767C417204498DE6C5EF442BD0CD222CFB67E6A1133E293F7 CCC_DATA_14=312E9B3897976FFE5B861E9F1FFD0B7DF14E3AFD205CCCD7DB36E80E187C054AAAA0824138F13F93 CCC_DATA_15=785E33975B3E144C8C4E49ADAA1684854C6C9365E899AF923931D3712213059A713831CC76451803 CCC_DATA_16=9361B03E7734C3C4A0572989F0D81B2909EF9B2B02A0C673D8F73F4E3D5751D0B8010E3035D2F4D6 CCC_DATA_17=291D5F19F57A42FE69DD296B7DEFDE55E71DA42474F5F42DF7035D2CD55102FE6E611763DC596145 CCC_DATA_18=378AB1B47A8F0A61ADAE8521A3794E9A7CABC751FCC94F6A2B66CD07C02E4CF7B9FDAB338DB5943A CCC_DATA_19=63195B0792AAA10F5568605232B0BC5D168A64D6B8B0CD71AE79A43B2E38759251D099E47A3AF3D0 CCC_DATA_20=A35322D503DE321A6896F02146BE92F437372F656FA4F7C17590A5EFCB98BF6EEBE143EFC0750928 CCC_DATA_21=0BF94951B7DC46EE137554821A4B438FDCE87EA7803E156C1F585BDFCD6408D85D5129152D6F0340 CCC_DATA_22=E557C3FFA3068E7FEF0C266F4A3BDB6A933649609A5138F8A3610DD0D11011B668D4B50BDA438AC9 CCC_DATA_23=4FB0399AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_25=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CCC_DATA_26=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF HWC_DATA_1=4348574305004150010000009143E0943EA5B5470000000000000000000000000000000000000000 HWC_DATA_2=00000000000000000F100218098500589E6CE783343ABC73AA1050CC303535383834394300000000 HWC_DATA_3=0000000024502EF1ED3FAE1C875937E7E57CA02F796D81E9B28A16F013D47D8549CC9440E80709E7 HWC_DATA_4=FDF8B8861FE6928ED4EFFFD06458D77CEC9AAB6A7D6A6266AFBE2CF6AF40C1512F77D625B3D93BF7 HWC_DATA_5=D327BEDDFD2BB7B1B8DD470204474A78AB4D191221D2C2C49A92F2C8E2D82A36CA0A98B94DF30842 HWC_DATA_6=BEC5E6B523CEE51DBAB1069CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF HWC_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_1=A15DE4470208BBBD994C3AE274AF92AA744 FDABD8000000000000006244070000000000000180700 SIMLOCK_DATA_2=000000000050000005FFFFFF00B4000005F FFFFF0118000005FFFFFF017C000005FFFFFF01E00000 SIMLOCK_DATA_3=05FFFFFF0244000005FFFFFF02A8000005F FFFFF000000007FFF6F07FFFFFFFFF800030C03000503 SIMLOCK_DATA_4=000000007FFF6F3EFFFFFFFFC000030F020 00103000000007FFF6F3FFFFFFFFFC000031102000103 SIMLOCK_DATA_5=000000007FFF6F07FFFFFFFF07FE0313080 00503000000007FFF6F07FFFFFFFF07FE031B08000503 SIMLOCK_DATA_6=000000007FFF6F07FFFFFFFFF8000323030 00503000000007FFF6F3EFFFFFFFFC000032602000103 SIMLOCK_DATA_7=000000007FFF6F3FFFFFFFFFC0000328020 00103000000007FFF6F07FFFFFFFF07FE032A08000503 SIMLOCK_DATA_8=000000007FFF6F07FFFFFFFF07FE0332080 00503000000007FFF6F07FFFFFFFFF800033A03000503 SIMLOCK_DATA_9=000000007FFF6F3EFFFFFFFFC000033D020 00103000000007FFF6F3FFFFFFFFFC000033F02000103 SIMLOCK_DATA_10=000000007FFF6F07FFFFFFFF07FE034108 000503000000007FFF6F07FFFFFFFF07FE034908000503 SIMLOCK_DATA_11=000000007FFF6F07FFFFFFFFF800035103 000503000000007FFF6F3EFFFFFFFFC000035402000103 SIMLOCK_DATA_12=000000007FFF6F3FFFFFFFFFC000035602 000103000000007FFF6F07FFFFFFFF07FE035808000503 SIMLOCK_DATA_13=000000007FFF6F07FFFFFFFF07FE036008 000503000000003F007F206F07FFFFF800036803000503 SIMLOCK_DATA_14=000000003F007F206F3EFFFFC000036B02 000103000000003F007F206F3FFFFFC000036D02000103 SIMLOCK_DATA_15=000000003F007F206F07FFFF07FE036F08 000503000000003F007F206F07FFFF07FE037708000503 SIMLOCK_DATA_16=000000003F007F206F07FFFFF800037F03 000503000000003F007F206F3EFFFFC000038202000103 SIMLOCK_DATA_17=000000003F007F206F3FFFFFC000038402 000103000000003F007F206F07FFFF07FE038608000503 SIMLOCK_DATA_18=000000003F007F206F07FFFF07FE038E08 000503000000003F007F206F07FFFFF800039603000503 SIMLOCK_DATA_19=000000003F007F206F3EFFFFC000039902 000103000000003F007F206F3FFFFFC000039B02000103 SIMLOCK_DATA_20=000000003F007F206F07FFFF07FE039D08 000503000000003F007F206F07FFFF07FE03A508000503 SIMLOCK_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF SIMLOCK_DATA_25=FFFFFFFF SIMLOCK_KEY_DATA_1=7931A11AF81FF782AA459BA3635B308 093C8C8C6782A5DA6F3E0E476654457DB60FCBEB53564A4FC SIMLOCK_KEY_DATA_2=6C60438196F1E163114282E22F75D7E 6662390F0FEF5010395398AC259092995C381D939B72197DF SIMLOCK_KEY_DATA_3=8E9B91C3ADD7798335AB46DFD0ACF4C 4EA407B41 SUPERDONGLE_KEY_DATA_1=D4391CE82C935CA361E0D3A96C5 72C0D52C7D45C82340DCD28266965B3D61B60320F14E7C6360 05A SUPERDONGLE_KEY_DATA_2=AD54410AD488424C7C5D43A525D 720ED4B2F74B2058DBBEA36A6D5F759652ED231A5C67D815EE 386 SUPERDONGLE_KEY_DATA_3=C307EAAF930040C97DC1F1CEC09 A8B70 CHECKSUM=-1 [CERT_PROG_DATA_OUT_APE] PRODUCTCODE=0552058 PSN=CRC916404 HWID=1527 CHECKSUM=-1 [MISC_PROG_DATA_OUT] RF_DATA_1=00010018000000721BED00000000000000000000 000000000000000000000000000000000000FFD1 RF_DATA_2=FFF70007FFFFFFFFFFDEFFB4FFB4FFB400000000 0000000000000000000000000000000000000000 RF_DATA_3=0000000000000000000000000000000000000000 000000000000000000000000000000000000FFDB RF_DATA_4=0077000100040000000000020062007DFFCE40BD 40000000004A00002C7A2C7A2C7A2C7A278D22B0 RF_DATA_5=1F5C1C49197816A8148B12C011370FCF0E970D70 0C5A0B642C7A2C7A2C7A2AFF25AE20E31D1D1A08 RF_DATA_6=178E158C13D5123810D10F510E170CE00BCE0AC8 0006274A000722E7000722E70004006E1B230000 RF_DATA_7=0000000000000000000000000000000000000000 000000000000FFDAFFF8001000100000FFF0FFDE RF_DATA_8=FFDAFFC700000000000000000000000000000000 0000000000000000000000000000000000000000 RF_DATA_9=0000000000000000000000000000000000000000 000000000000000500040000000000060062004B RF_DATA_10=003240BD4000FF72004600003137297824281FC E1C3918E5161413D711EB10410ED90D910CAC0BE7 RF_DATA_11=0B230A6E0A6E0A6E2ED8273422191DC71A47178 61546136511BB100F0EA90D710C850BBC0AFB0A33 RF_DATA_12=0A6E0A6E00002ED8000127DA000224A30008006 E1B0D000000000000000000000000000000000000 RF_DATA_13=00000000000000000000000E001600160016000 60006FFFDFFEBFFC9000000000000000000000000 RF_DATA_14=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 RF_DATA_15=00000000000000000000000D0062004B003240B D40000000004A0000334329A9248B20E51D3F19BA RF_DATA_16=16761408121C10520EE90DA20CBC0BF80B330A7 F0A7F0A7F2FF8276022731E321ACE180515B213EC RF_DATA_17=126110AB0F3C0DF30D170C330B730AB90A7F0A7 F00002FF80001280E0002246C000F000400000000 RF_DATA_18=00100062007DFFCE40BD40000000005100001FC E1FCE1FCE1FCE1FCE1FCE1FCE1D0E1A1C17EF1604 RF_DATA_19=1429126E10E50F8D0E660D3F0C391FCE1FCE1FC E1FCE1FCE1FCE1E9C1C13193216C414BF1314117F RF_DATA_20=102D0F290E0C0CF00BD500081E9C000A1B9C000 A19DE00120062004B003240BD4000FF72004D0000 RF_DATA_21=245A245A245A21CA1DC21A6E17BE1591139511C A10310ED90DE30D0E0C290B640B640B64245A245A RF_DATA_22=22CC20851C881953169A147112A411110FC40E9 10DBE0CDB0C0B0B3C0B640B64000222CC00041ED1 RF_DATA_23=00041C8800140062004B003240BD40000000005 1000022B022B022B020621CAC19AA175C158113B6 RF_DATA_24=11EB10410EE90DF30D0E0C390B750B750B7522B 022B0220D1FE41C0D190F1691147112B4113E1006 RF_DATA_25=0EF70E250D690C8A0BC20B750B750002220D000 41E3E00041C0D0016001000170000FFD400000000 RF_DATA_26=006A0000000000170004FFFF000200180054000 00000000000000000000000000000000000000000 RF_DATA_27=00000000000000000000000000000000FFF7000 00000000000000000000000000000000000000000 RF_DATA_28=000000000000000000000000000000000000000 000000019000402310011001A006E1BB900000000 RF_DATA_29=000000000000000000000000000000000000000 000000000FFDEFFE8000500000000001B00120000 RF_DATA_30=FFF700000000000000000000000000000000000 00000000000000000000000000000000000000000 RF_DATA_31=000000000000000000000000000000000000000 000000000001B000400000000001C0062007DFFE7 RF_DATA_32=40BD40000000004600002B642B642B642B6425F 321581E351BD71947161413E7121C10930F3B0E04 RF_DATA_33=0CDD0BD70AD12B642B642B64291F23A11F431BB 2190316AD14A0131A11C2101F0EC80D960C5C0B4B RF_DATA_34=0A3A000625340007210E0007210E001D000A000 30001000300000001001F0062007DFFE740BD4000 RF_DATA_35=0000004D00001E561E561E561E561E561E561E5 61BC61916170A158113A611EB10720F2B0DF30CDD RF_DATA_36=0BD71E561E561E561E561E561E561CEA1A9517E C15AF13BC121710AA0F810E7E0D880C570B460008 RF_DATA_37=1CEA000A1A25000A188A00210024000C0000000 00000000000000000000000000000000000BC0000 RF_DATA_38=0000000000000000000000220050000301E100F F0000000000000000000000000000000006030006 RF_DATA_39=001601C00BB206030006001601A90BB20603000 8001801E0096B06030008001801A30EBE00000000 RF_DATA_40=0000000000000000000000000000002C00B6000 60000000905BC002400040000000404730108000F RF_DATA_41=0086021301E01573140B13F8001D001D0009007 2FFB900A001B0FFF03295FFF000190041001D0042 RF_DATA_42=002100410025004000290040002E0040003B003 60046002F0050002800580024006000200066001D RF_DATA_43=006C001A0072001800770015007A0016007C001 60083001300890010008E000E0093000C0097000B RF_DATA_44=009C000800A1000600A5000500A9000300AD000 200B1000100B5FFFF00B8FFFE00BCFFFD00BFFFFD WARRANTY_DATA_1=00020001000001B8000000000000000000 FFFF000000000000000000000000000000000000000000 WARRANTY_DATA_2=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_3=0000000000000000000000000000000000 01000000000100000000FFFF0000000000000000000000 WARRANTY_DATA_4=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_5=0000000000000000000000000000000000 0000000000000000000001020001000000000000000000 WARRANTY_DATA_6=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_7=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_8=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_9=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 WARRANTY_DATA_10=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_11=000000000000000000000000000000000 00000000000000000000000000000000000000000000000 WARRANTY_DATA_12=0000000001000200 PROD_DATA_1=00040006000103FC8200010028010100000000 000000000000000000000000000000000000000000 PROD_DATA_2=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_3=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_4=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_5=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_6=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_7=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_8=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_9=00000000000000000000000000000000000000 000000000000000000000000000000000000000000 PROD_DATA_10=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_11=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_12=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_13=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_14=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_15=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_16=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_17=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_18=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_19=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_20=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_21=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_22=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_23=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_24=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_25=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 PROD_DATA_26=0000000000000000000000000000000000000 00000000000000000000003000A4352433931363430 PROD_DATA_27=3400000400083035353230353800000500083 035323533323700000900053135323700001C000202 BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020 FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK_DATA_1=01340008000000010300012000300000000000 00000D0000000000000019F815E800000000000000 LOCK_DATA_2=00000000000000000000000000000000000000 0000E0000000800000000600000002000000AB0FBD LOCK_DATA_3=96AF2AC271D26264AFDEAD0300724D4BDE43AF 0E4116E5D5E3457E923806829420A5DB540DFB184B LOCK_DATA_4=DF197B78DC5F7DC50E90DD29FBD9A54AD9E068 CF0780CC2D309F4ABEAF2633694E23A613A1ECE4B5 LOCK_DATA_5=CB424772D85DCF71196CBD275FDA1B80ABBE18 D397BDEC47545D1CE1362AA4E424F707AC853FCFF5 LOCK_DATA_6=B9468235480C3E47D4A271EF84361B8C1550E0 AFE1787A2F91E50B3F838CB17E2E8EC7757BE00100 LOCK_DATA_7=00D00000000500000002000000AB0FBD96AF2A C271D26264AFDEAD0400C6111CDBAB8509288A79B3 LOCK_DATA_8=92210484FFE04E79E99DBF8488D33B040DD372 4933034563A80C8FE71C4569BBAE69213FB8555359 LOCK_DATA_9=A2C4B1B6F4D2FAC004F2224DF99BC5C8BFF3F8 60CC226BA2D2C163CAD62B16FD3A09462B72012C04 LOCK_DATA_10=0DF2CC6B66CDF090E248B223565D27BFE051A 887A81767CA0F814520AA9B7175557210CCE0EB6415 LOCK_DATA_11=4ADD7B9267D175A79033A0285056AFB717C48 C3472AB263B7A698D413AD4C5C25565D6C46FF66BFC LOCK_DATA_12=3724685EBCE4D4AC52094B693EF764F7F183B 2C4538F27AED754A52B41B63409275E0376E5A86832 LOCK_DATA_13=345F86DDC5AB28E45A07D52673FFFFFFFFC00 000000200000002000000AB0FBD96AF2AC271D26264 LOCK_DATA_14=AFDEAD0600B717F91738DEC2C9F03F31BDE43 039C2B3D0625D3CE2E63E0C32C54716C6471D793A8D LOCK_DATA_15=3140BB5A9E51CBA49FD00DC89E95034F018FB B47DFA53CBC9C8A32DA21F3E385C0D1536880A0E1AD LOCK_DATA_16=6ED623F80F6B1950D2E932A8E8DB61002AC78 E3D0C90A6ABED9DBFBF5C364CDE335A9F62E10DBA19 LOCK_DATA_17=F0D52D6B312D4C9F316C03E15CF4F4528802B 39739D970868C60BA50B236DED02E0E6A767AEB8F5A LOCK_DATA_18=E06DABEFDD1FA35D197B773CB3CE11F6DE5D5 EED78A78D525FA5E6ED80357BA8C2EB5EC90F340535 LOCK_DATA_19=DC07A59FD648E5D9E61F9F46AC00000000000 0000000000000000000000000000000000000000000 LOCK_DATA_20=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_21=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_22=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_23=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_24=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_25=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_26=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_27=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_28=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_29=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_30=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_31=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_32=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_33=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_34=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_35=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_36=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_37=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_38=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_39=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_40=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_41=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_42=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_43=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_44=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_45=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_46=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_47=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_48=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_49=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_50=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_51=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_52=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_53=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_54=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_55=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_56=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_57=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_58=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_59=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_60=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_61=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_62=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_63=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_64=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_65=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_66=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_67=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_68=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_69=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_70=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_71=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_72=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_73=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_74=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_75=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_76=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_77=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_78=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_79=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_80=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_81=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_82=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_83=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_84=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_85=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_86=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_87=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_88=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_89=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_90=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_91=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_92=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_93=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_94=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_95=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_96=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_97=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_98=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_99=0000000000000000000000000000000000000 0000000000000000000000000000000000000000000 LOCK_DATA_100=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_101=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_102=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_103=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_104=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_105=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_106=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_107=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_108=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_109=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_110=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_111=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_112=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_113=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_114=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_115=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_116=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_117=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_118=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_119=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_120=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_121=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_122=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_123=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_124=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_125=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_126=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_127=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_128=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_129=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_130=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_131=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_132=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_133=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_134=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_135=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_136=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_137=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_138=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_139=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_140=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_141=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_142=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_143=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_144=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_145=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_146=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_147=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_148=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_149=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_150=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_151=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_152=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_153=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_154=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_155=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_156=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_157=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_158=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_159=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_160=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_161=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_162=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_163=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_164=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_165=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_166=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_167=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_168=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_169=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_170=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_171=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_172=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_173=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_174=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_175=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_176=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_177=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_178=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_179=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_180=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_181=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_182=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_183=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_184=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_185=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_186=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_187=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_188=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_189=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_190=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_191=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_192=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_193=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_194=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_195=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_196=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_197=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_198=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_199=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_200=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_201=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_202=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_203=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_204=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_205=000000000000000000000000000000000000 00000000000000000000000000000000000000000000 LOCK_DATA_206=000000000000020001800003000103000400 0107000600010000070001000008000100 LOCK120_DATA_1=00780004000003B08000000000000006244 070000000000000180700000000000050000005FFFFFF LOCK120_DATA_2=00B4000005FFFFFF0118000005FFFFFF017 C000005FFFFFF01E0000005FFFFFF0244000005FFFFFF LOCK120_DATA_3=02A8000005FFFFFF000000007FFF6F07FFF FFFFFF800030C03000503000000007FFF6F3EFFFFFFFF LOCK120_DATA_4=C000030F02000103000000007FFF6F3FFFF FFFFFC000031102000103000000007FFF6F07FFFFFFFF LOCK120_DATA_5=07FE031308000503000000007FFF6F07FFF FFFFF07FE031B08000503000000007FFF6F07FFFFFFFF LOCK120_DATA_6=F800032303000503000000007FFF6F3EFFF FFFFFC000032602000103000000007FFF6F3FFFFFFFFF LOCK120_DATA_7=C000032802000103000000007FFF6F07FFF FFFFF07FE032A08000503000000007FFF6F07FFFFFFFF LOCK120_DATA_8=07FE033208000503000000007FFF6F07FFF FFFFFF800033A03000503000000007FFF6F3EFFFFFFFF LOCK120_DATA_9=C000033D02000103000000007FFF6F3FFFF FFFFFC000033F02000103000000007FFF6F07FFFFFFFF LOCK120_DATA_10=07FE034108000503000000007FFF6F07FF FFFFFF07FE034908000503000000007FFF6F07FFFFFFFF LOCK120_DATA_11=F800035103000503000000007FFF6F3EFF FFFFFFC000035402000103000000007FFF6F3FFFFFFFFF LOCK120_DATA_12=C000035602000103000000007FFF6F07FF FFFFFF07FE035808000503000000007FFF6F07FFFFFFFF LOCK120_DATA_13=07FE036008000503000000003F007F206F 07FFFFF800036803000503000000003F007F206F3EFFFF LOCK120_DATA_14=C000036B02000103000000003F007F206F 3FFFFFC000036D02000103000000003F007F206F07FFFF LOCK120_DATA_15=07FE036F08000503000000003F007F206F 07FFFF07FE037708000503000000003F007F206F07FFFF LOCK120_DATA_16=F800037F03000503000000003F007F206F 3EFFFFC000038202000103000000003F007F206F3FFFFF LOCK120_DATA_17=C000038402000103000000003F007F206F 07FFFF07FE038608000503000000003F007F206F07FFFF LOCK120_DATA_18=07FE038E08000503000000003F007F206F 07FFFFF800039603000503000000003F007F206F3EFFFF LOCK120_DATA_19=C000039902000103000000003F007F206F 3FFFFFC000039B02000103000000003F007F206F07FFFF LOCK120_DATA_20=07FE039D08000503000000003F007F206F 07FFFF07FE03A508000503FFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF LOCK120_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF000100507931A11A LOCK120_DATA_25=F81FF782AA459BA3635B308093C8C8C678 2A5DA6F3E0E476654457DB60FCBEB53564A4FC6C604381 LOCK120_DATA_26=96F1E163114282E22F75D7E6662390F0FE F5010395398AC259092995C381D939B72197DF00020014 LOCK120_DATA_27=8E9B91C3ADD7798335AB46DFD0ACF4C4EA 407B410003007000000000000000000000000000000000 LOCK120_DATA_28=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 LOCK120_DATA_29=0000000000000000000000000000000000 0000000000000000000000000000000000000000000000 LOCK120_DATA_30=00000000000000000000000000000000 BB_DATA_1=0135000800000004010000000001000201190002 000CFE05010003000000753300000004000C0101 BB_DATA_2=0100CC090000D25300000005000C020101000000 00002DF901000007000C040202009B0400000000 BB_DATA_3=00000008000C050303004F08D20F2A0100000011 000C0E0601000000000012270000 post resalt Last edited by king.of.gsm; 04-12-2010 at 16:47. |
04-12-2010, 17:11 | #15 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | look at ur orginal rpl missing hwc_data try to writ this rpl with mxky 4shared.com - online file sharing and storage - download BB5_35766601314146_BACK.rpl then repair sd then go to pm >click sd auth and writ pm and post here result |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
