Old 10-16-2012, 15:59   #1 (permalink)
Member: 1709500
Thanks Meter: 8
6110 n SECURITY_TEST failed!
how to clear this problem
i try recover cert
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 07C00005D87D0058F2CA4E59C47180907F5AC275
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 1A6CB332579705F9ED945C0AD7530A7055C2BCE8
Begin Certificate Request ...
[InternalErrorFault] CERT [0546008] data not found in database (case id=0xCE03)
Phone type: RM-122 (Nokia 6110)
SW version: V 03.58 19-06-07 RM-122 (c) Nokia
ApeCoreSw: 03.58
Imei plain: 35766601408451-8
Product code: 0546017
Battery voltage: 4321 mV, current: 7 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
Imei net: 357666014084518
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
write pm error
Section: 1
- Key: 0, size 114 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 98 bytes written.
Warning: failed to write 1 - 4 (110 bytes)
- Key: 5, size 4 bytes written.
- Key: 6, size 98 bytes written.
Warning: failed to write 1 - 8 (110 bytes)
- Key: 13, size 98 bytes written.
- Key: 15, size 4 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
Warning: failed to write 1 - 26 (110 bytes)
- Key: 27, size 4 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
Warning: failed to write 1 - 44 (182 bytes)
- 120 skipped
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Completed in 4.078 s
Old 10-16-2012, 16:30   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-122.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
Old 10-17-2012, 06:48   #3 (permalink)
Member: 1709500
Thanks Meter: 8
same problem plz help
ApeCoreSw: 03.58
Using cached productData.
PRIVATE ID: A05C3812381B1201CD60EE6D009FF3BBC74E944A
Updating SUPERDONGLE_KEY ...OK
Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\6110n_RM-122.txt ...
Writing RF settings to phone ...OK, finished. 21 Records found.
Writing BB settings to phone ...OK, finished. 8 Records found.
Done.
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
Original Imei: 35766601408451
Original Product code: 0546008
Bluetooth ID: 001CD661C903
SIMLOCK PA identifier:
[0] PA_SL2
ApeCoreSw: 03.58
Battery voltage: 4562 mV, current: 3 mA
Language Pack:
- not available.
Counter: 0/3, 0/10
Old 10-17-2012, 06:51   #4 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 360
go pm tab load pm 1 and 309
and press rapeir super sd and after this press supper sd outh
after supper sd outh just write
100% solve your problem
Page generated in 0.20783 seconds with 7 queries
