Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 08-25-2010, 07:21   #1 (permalink)
Member: 1211533
Sonork: 100.1579942
6120c unlock problem .need help argently (ANSWERED)
Imei net: 359342039163830
Version: SIMLOCK SERVER
Provider: Telstra Mobile Comms, Country: Australia
Counter: 0/3, 0/10
CONFIG_DATA: 5050100058056920
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F
BLOCK 2: 1=LOCKED (MCC+MNC): 50501F, DATA=50501F
Backup already exist.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 07.10 15-07-09 RM-243 (c) Nokia
ApeCoreSw: 07.10
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
Custom loader not available for this ID !
whats fault ?
Old 08-25-2010, 07:23   #2 (permalink)
Member: 1211533
Sonork: 100.1579942
check info
Phone Type: RM-243 (Nokia 6120)
SW Version: V 07.10 15-07-09 RM-243 (c) Nokia
Imei plain: 35934203916383-0
Product Code: 0567116
ApeCoreSw: 07.10
ApeVariant: rofs_version_inforofx_version_info
ApeTest: rm243_ENO_A_2009wk15v0.100
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SECURITY_TEST passed
Counter: 0/3, 0/10
bus check info
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0D50000F118C00524B294C1D4EAE79C733D8796F
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Please select correct loader version from 'Config' menu !
Old 08-25-2010, 07:27   #3 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Calculate Nck code and simply hit that code.....NO risk....safe method
The Following User Says Thank You to ..:::YMG:::.. For This Useful Post:
Old 08-25-2010, 07:29   #4 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: 100.1590892
Originally Posted by u & me View Post
check info
ApeCoreSw: 07.10
Language Pack:
- not available.
Counter: 0/3, 0/10
bus check info
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Old 08-25-2010, 07:30   #5 (permalink)
Member: 681216
Sonork: 100.1584492
connect UFS box & try with this soft
http://www.mediafire.com/download.php?mvmyjzgz5nj
Old 08-25-2010, 07:33   #6 (permalink)
Member: 851193
Sonork: 100.1615313
just clean fbus point and try several time
or use cyclone box as it has latest flash loaders
Old 08-25-2010, 07:34   #7 (permalink)
Member: 851193
Sonork: 100.1615313
Originally Posted by rezactgbd View Post
if you try this software
1st make RPL and pm backup else it may be a big trouble
The Following User Says Thank You to kariakala For This Useful Post:
Old 08-25-2010, 07:36   #8 (permalink)
Raznet's Avatar
Member: 564325
best method just use usb and chk bus than update simlock because 6120c can be unlocked only by usb interface tested by me
good luck
Old 08-25-2010, 07:37   #9 (permalink)
Member: 667126
hey man......use jaf.......... change cable......use 7 pin cable.......do with out display.....
Old 08-25-2010, 07:44   #10 (permalink)
Member: 392149
Sonork: 100.1597220
Bro what interface you use change interface and just try again fhone is unlocked 100%
Old 08-25-2010, 07:46   #11 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
try with hwk all will unlock with out internet you can unlock any SL2 nokia mobile.
Old 08-25-2010, 07:46   #12 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
its a SL3 you cannot unlock
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 08-25-2010, 07:46   #13 (permalink)
Member: 681216
Sonork: 100.1584492
1. Write back PM backup, it should take backup automatically
2. Reunlock
3. Buy proper tool
Old 08-25-2010, 07:49   #14 (permalink)
Mr.3.'s Avatar
Member: 962029
2. Reunlock
3. Buy proper tool
if u did this you will get startup fail...becoz its SL3 phone...
Old 08-25-2010, 07:50   #15 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Mr.3.
Mr.3.'s Avatar
Member: 962029
Sonork: 100.534744
are you sure it is sl3 .hmmmmmm this mobile i have only unlock this version this is what we could 9DDB has but this is not sl3 this is SL2 unlock with hwk it is very safe .your problem solve mx key is not working sometime because used server to unlock so hwk is not required this for server.
regards:
long lee
LG C320 unlock problem [SOLVED] khoavtran FuriouS TeaM Products 7 05-07-2011 15:56
iphone display brightess problem!!! mobile_juice iPhone, iPad, iPod Hardware Repair 5 01-17-2011 16:11
Need for Speed Hot Pursuit Version: 1.0.2 UPDATE Trafikci258 iPhone ,iPod & iPad (Apple Inc. Products) 4 01-05-2011 11:25
i need this flash file.....(Solved) amralkareem Dragon Box 15 12-22-2010 13:02
Help me 3GS error 1601 and 21 may be a hardware or not. somkit iPhone ,iPod & iPad (Apple Inc. Products) 3 12-22-2010 11:27
Page generated in 0.46291 seconds with 11 queries
