6120c white display then goes blue,Need some help. Set come in blinking problem after flash when i press power button its shows white display then goes blue and hang,also tried with F bus and USB but no luck. files downloaded with 0550022 product code from Mx-key support.Plz need its solution Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Processing MCU file: rm243_06.01_prd_core.fpsx [BB5,XSR 1.5] size: 43.68 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CBE0B3A CMT SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 030001045C8300580D01E669E724CD2AEF53DFD1 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT ROM ID: A8C1D6713E691FF8 Flashing CMT Update Server Data, ULO: 0x3A00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, XSR: 0x1E36FB bytes Update Server code succesfully sent to phone. Pooling for ADL device ... Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 34CED174 Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 74.81 MB Flash programming ... CMT PAPUBKEYS: 0FE1BA92D924A658E4800780FA6F4868100AC947 (RAP Certificate 68 v1) written. Programming completed in 1 min 33.125 s Processing PPM file: rm243_06.01_prd_vB20_01_mea_a.fpsx [BB5,XSR 1.5] size: 16.03 MB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103 Erase size: 27.00 MB Flash programming ... Programming completed in 35.937 s Processing CNT file: rm243_06.01_prd_UDA_Pearl_White.fpsx [BB5,XSR 1.5] size: 111.26 KB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105 Erase size: 45.25 MB Flash programming ... Programming completed in 0.250 s Total time for flashing process(boot+erase+write) was 2 min 52.203 s Pooling for ADL device ... Timeout, no usb device found. Flashing completed in 3 min 44.156 s Phone not responding ! |
daar plzzz flash with rj-45 cable with new leatest version....ur problm will be solved....!!!! |
Done,solved No one help me, I have solved my problem After flash Just write this file in ppm tab:D 6120_blank_10.fpsx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Processing PPM file: 6120_blank_10.fpsx [BB5,XSR 1.5] size: 504.33 KB Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 No Erase header defined, erase will be skipped CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 030001045C8300580D01E669E724CD2AEF53DFD1 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 TransmissionMode: DDR&TX2 Erase skipped. Flash programming ... Programming completed in 2.906 s Total time for flashing process(boot+erase+write) was 9.563 s Flashing completed in 19.813 s Phone Type: RM-243 (Nokia 6120) SW Version: V 06.01 02-09-08 RM-243 (c) Nokia Imei plain: 358641017XXXXX Product Code: 0550022 ApeCoreSw: 06.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Imei net: 3586410174XXXXX Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
bro my phone 6120c same poblam i write 6120_blank_10.fpsx but phone no on plz help. |
you can get file from here. Nokia 6120c-----7.20 -- Urdu |
u can download this file http://rapidshare.com/files/45117393...ase_rapido.rar |
