Old 03-05-2011, 10:26   #1 (permalink)
madni shah's Avatar
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
6120c white display then goes blue,Need some help.
Set come in blinking problem after flash when i press power button its shows white display then goes blue and hang,also tried with F bus and USB but no luck. files downloaded with 0550022 product code from Mx-key support.Plz need its solution
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
Processing MCU file: rm243_06.01_prd_core.fpsx
[BB5,XSR 1.5] size: 43.68 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101031105, 4003192101031103, 400C192101031103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Pooling for ADL device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CBE0B3A
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
CMT EM0 ID: 00000295
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 030001045C8300580D01E669E724CD2AEF53DFD1
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: A8C1D6713E691FF8
Flashing CMT Update Server Data, ULO: 0x3A00 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, XSR: 0x1E36FB bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 34CED174
Verifying communication to device OK.
Partitioning....
Partitioning complete
Erase size: 74.81 MB
Flash programming ...
CMT PAPUBKEYS: 0FE1BA92D924A658E4800780FA6F4868100AC947 (RAP Certificate 68 v1) written.
Programming completed in 1 min 33.125 s
Processing PPM file: rm243_06.01_prd_vB20_01_mea_a.fpsx
[BB5,XSR 1.5] size: 16.03 MB
Erase size: 27.00 MB
Programming completed in 35.937 s
Processing CNT file: rm243_06.01_prd_UDA_Pearl_White.fpsx
[BB5,XSR 1.5] size: 111.26 KB
Erase size: 45.25 MB
Programming completed in 0.250 s
Total time for flashing process(boot+erase+write) was 2 min 52.203 s
Timeout, no usb device found.
Flashing completed in 3 min 44.156 s
Phone not responding !
Old 03-05-2011, 11:12   #2 (permalink)
Member: 1512913
Sonork: sUn seT oF lifE
Thanks Meter: 3
daar plzzz flash with rj-45 cable with new leatest version....ur problm will be solved....!!!!
Old 03-06-2011, 05:20   #3 (permalink)
madni shah's Avatar
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Done,solved
No one help me, I have solved my problem
After flash Just write this file in ppm tab
6120_blank_10.fpsx
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Processing PPM file: 6120_blank_10.fpsx
[BB5,XSR 1.5] size: 504.33 KB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
No Erase header defined, erase will be skipped
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030 - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947
TransmissionMode: DDR&TX2
Erase skipped.
Programming completed in 2.906 s
Total time for flashing process(boot+erase+write) was 9.563 s
Flashing completed in 19.813 s
Phone Type: RM-243 (Nokia 6120)
SW Version: V 06.01 02-09-08 RM-243 (c) Nokia
Imei plain: 358641017XXXXX
Product Code: 0550022
ApeCoreSw: 06.01
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SECURITY_TEST passed
Imei net: 3586410174XXXXX
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to madni shah For This Useful Post:
Old 03-06-2011, 08:23   #4 (permalink)
alpona_su's Avatar
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 146
bro my phone 6120c same poblam i write 6120_blank_10.fpsx but phone no on plz help.
Old 03-06-2011, 09:39   #5 (permalink)
madni shah's Avatar
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Download v7.20 flash your phone with this version, then write this file 6120_blank_10.fpsx and post results.
you can get file from here.
Nokia 6120c-----7.20 -- Urdu
Old 03-06-2011, 10:05   #6 (permalink)
Member: 857624
Thanks Meter: 20
Smile
brother back up u r 6120 rpl then erase flash ( use 6120 erase rapido .bin file) then flash with new version then re write rpl. u r problem 100% solve i tested this solution in several 6120
u can download this file
http://rapidshare.com/files/45117393...ase_rapido.rar
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 17:24
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 12:35
Page generated in 0.32400 seconds with 8 queries
