Old 05-21-2010, 17:32   #1 (permalink)
Member: 1231949
Sonork: 12
Thanks Meter: 42
7210c simlock data corrupted
please how can i repair simlock data corrupted by mx key
this is a report of mx key
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 08D0000A1C7C7D568CFE1D85B514B91F955FA9E5
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35318003219711
Original Product code: 0566808
Bluetooth ID: 002547DB82F8
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 05.21 20-10-08 RM-436 (c) Nokia
Imei plain: 35318003219711-6
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
UFS2 SarasSoft disconnected.
please help me
Old 05-21-2010, 18:03   #2 (permalink)
Thanks Meter: 4,071
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
please help me
just update simlock
your problem will be solved
Old 05-21-2010, 18:04   #3 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
just unlock your phone..............Go imei &security tick Make SIM RPL > Update Sp lock
Old 05-21-2010, 18:06   #4 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
please help me
Search in forum, so many times post in forum brother.
try with:
- check init simlock.
- update splock.
if not restore simlock "C:\mobileEx\3.4\data\backup\BB5_RM-237_351939038425157_SIM.RPL"
B.R.,
B.uttam
Old 05-21-2010, 20:12   #5 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 892
Arrow thanks a lots
nice job sir je u r great
The Following User Says Thank You to amit kanpur For This Useful Post:
Old 05-22-2010, 12:05   #6 (permalink)
Member: 1295798
Sonork: brista786
Thanks Meter: 97
use this metohed i hope ur problem will be solved
Phone logs when Scanned in Mx-key:
Phone Type: RM-240 (Nokia 6500s-1)
SW Version: V 10.00 06-03-09 RM-240 (c) Nokia
Imei plain: 35765901674649-9
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
PROCEDURE TO FOLLOW
1.Repair SD
2.SUPER SD Auth
3.PM Write
4.Repair SIMLOCK
Step by Step:
1. Repair SD.
Under IMEI & Security tab click IMEI Rebuild and click "Repair SD". Wait until mx-key finishes it's job..
Sample Log:
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 10.00 06-03-09 RM-240 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 4.906 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
After repairing SUPERDONGLE_KEY, SECURITY_TEST has been damaged.
see status:
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST failed!
proceed to next steps to restore SECURITY_TEST.
2. SUPER SD Auth.
Under PM tab click "SUPER SD Auth". Again wait for mx-key to finish..
Sample Log:
Restarting phone ...
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
After the unit has been authorized, you can now write pm fields 1 and 309.. For my case, i use a complete pm file but chose to skip simlock area.
3. Write good pm file.
Still under PM tab..Locate "Load from file" then click it.. a folder will pop-up asking you to choose the pm file you would like to write.. pick the file then click "Open". Wait for mx-key to finish.
Sample Log:
Completed in 7.828 s
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 40, size 16 bytes written.
- Key: 41, size 182 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 36 bytes written.
- Key: 44, size 182 bytes written.
Section: 2
- Key: 0, size 448 bytes written.
Section: 4
- Key: 1, size 48 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
- Key: 28, size 2 bytes written.
Section: 8
- Key: 1, size 12 bytes written.
- Key: 7, size 8 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 2 bytes written.
- Key: 7, size 1 bytes written.
- Key: 8, size 1 bytes written.
- Key: 9, size 1 bytes written.
- Key: 10, size 1 bytes written.
- Key: 11, size 1 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 2 bytes written.
- Key: 15, size 2 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 2 bytes written.
- Key: 18, size 16 bytes written.
- Key: 19, size 32 bytes written.
- Key: 20, size 32 bytes written.
- Key: 21, size 2 bytes written.
- Key: 22, size 2 bytes written.
- Key: 23, size 2 bytes written.
- Key: 24, size 2 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 29, size 2 bytes written.
- Key: 30, size 2 bytes written.
- Key: 31, size 2 bytes written.
- Key: 32, size 2 bytes written.
- Key: 33, size 2 bytes written.
- Key: 34, size 2 bytes written.
- Key: 35, size 2 bytes written.
- Key: 36, size 2 bytes written.
- Key: 37, size 2 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 2 bytes written.
- Key: 44, size 2 bytes written.
- Key: 45, size 2 bytes written.
- Key: 46, size 2 bytes written.
- Key: 47, size 2 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 2 bytes written.
- Key: 51, size 2 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 2 bytes written.
- Key: 54, size 2 bytes written.
- Key: 55, size 2 bytes written.
- Key: 56, size 2 bytes written.
- Key: 57, size 2 bytes written.
- Key: 58, size 2 bytes written.
- Key: 59, size 2 bytes written.
- Key: 60, size 2 bytes written.
- Key: 61, size 2 bytes written.
- Key: 62, size 2 bytes written.
- Key: 63, size 2 bytes written.
- Key: 64, size 2 bytes written.
- Key: 65, size 4 bytes written.
- Key: 66, size 1 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 4 bytes written.
- Key: 69, size 4 bytes written.
- Key: 70, size 4 bytes written.
- Key: 71, size 16 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 13 bytes written.
Section: 31
- Key: 4, size 16 bytes written.
Section: 42
- Key: 0, size 2 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 40 bytes written.
- Key: 8, size 40 bytes written.
- Key: 9, size 40 bytes written.
- Key: 10, size 40 bytes written.
- Key: 11, size 40 bytes written.
- Key: 12, size 40 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
Section: 50
Section: 54
Section: 66
- Key: 0, size 2050 bytes written.
- Key: 1, size 240 bytes written.
- Key: 2, size 240 bytes written.
- Key: 3, size 1 bytes written.
- Key: 5, size 240 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 4 bytes written.
- Key: 8, size 4 bytes written.
- Key: 9, size 4 bytes written.
- Key: 10, size 240 bytes written.
- Key: 11, size 240 bytes written.
- Key: 16, size 4 bytes written.
- Key: 18, size 4 bytes written.
- Key: 20, size 4 bytes written.
- Key: 22, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 26, size 4 bytes written.
- Key: 28, size 4 bytes written.
- Key: 30, size 4 bytes written.
- Key: 32, size 4 bytes written.
- Key: 34, size 4 bytes written.
- Key: 57, size 8 bytes written.
- Key: 58, size 8 bytes written.
- Key: 59, size 8 bytes written.
- Key: 60, size 8 bytes written.
- Key: 61, size 8 bytes written.
- Key: 75, size 8 bytes written.
- Key: 76, size 8 bytes written.
- Key: 78, size 6144 bytes written.
- Key: 79, size 300 bytes written.
- Key: 80, size 60 bytes written.
- Key: 91, size 3 bytes written.
- Key: 92, size 3 bytes written.
- Key: 93, size 3 bytes written.
- Key: 94, size 3 bytes written.
- Key: 95, size 3 bytes written.
- Key: 96, size 3 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 4 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 4 bytes written.
- Key: 102, size 4 bytes written.
- Key: 103, size 6 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 116, size 120 bytes written.
- Key: 118, size 30 bytes written.
- Key: 119, size 1 bytes written.
- Key: 120, size 8 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 26, size 12 bytes written.
- 120 skipped
Section: 122
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 218
Section: 238
- Key: 1, size 1 bytes written.
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Section: 322
- Key: 0, size 1 bytes written.
Section: 334
Section: 339
- Key: 0, size 511 bytes written.
- Key: 1, size 511 bytes written.
Section: 341
- Key: 4, size 4296 bytes written.
Section: 354
- Key: 0, size 3 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Section: 362
- Key: 1, size 120 bytes written.
Completed in 9.594 s
after pm write, check the status of the unit..
Product Code: 0543754
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST has been restored.. Proceed to next step to repair SIMLOCK.
4.Repair SIMLOCK.
Under "IMEI & SECURITY" click Simlock locate and click "Repair SIMLOCK" in Options menu. Also click "Make SIMLOCK RPL" then then click "Update SpLock". Wait for mx-key to finish.
Sample Log:
Calculating SIMLOCK using security server ...
Completed in 4.672 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 357659016746499
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
After all procedure's are done, scan the unit again to check it's status..
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Unit successfully repaired.. thanks to Mx-key team..
cellular data suite kabel vingis Main Sales Section 0 11-25-1999 19:18
SimLock Level 4 counter HitMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-12-1999 00:17
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 Nk_Cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-10-1999 10:08
Cellular Data Suite Cables avaliable !!! vingis Main Sales Section 0 11-02-1999 17:35
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 nk.cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-14-1999 15:33
Page generated in 0.26444 seconds with 9 queries
