Old 05-15-2010, 13:59   #1 (permalink)
ahmed14's Avatar
Member: 389660
Thanks Meter: 60
6120s problem repaire simlock
Backup already exist.
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 08w35.08 28-11-08 RM-367 (c) Nokia
ApeCoreSw: 04.13
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot [rapidov11_2nd.fg](0x3AC0 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending ROM(0x11C4 bytes) ...OK
Sending SecurityBlock(0x2000 bytes) ...OK
Sending SimlockBinary(0x190 bytes) ...OK
Sending KEYS [SLPA] (0x1930 bytes) ...OK
Calculating LOCK data ...OK
Unlocked PM saved to "C:\mobileEx\3.4\data\backup\352914020846990_UNLOC KED.PM"
Writing Unlocked PM ... OK
Completed in 27.469 s
Restarting phone ...
access violation at adresse 04189c2e
The Following User Says Thank You to ahmed14 For This Useful Post:
Old 05-15-2010, 14:18   #2 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
ApeCoreSw: 04.13
Looks like a bug, if your phone is working fine, just ignore this error, if not then restart and try again.
The Following User Says Thank You to curvenger For This Useful Post:
Old 05-15-2010, 14:28   #3 (permalink)
ahmed14's Avatar
Member: 389660
Thanks Meter: 60
sam pronble...........................
Old 05-15-2010, 15:48   #4 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
Is it unlocked or what? Can the phone switch on?
Old 05-22-2010, 03:03   #5 (permalink)
Member: 458884
Same problem.......?????????????
Old 05-22-2010, 12:02   #6 (permalink)
Member: 1295798
Sonork: brista786
Thanks Meter: 97
use this metohed i hope ur problem will be solved
Phone logs when Scanned in Mx-key:
Phone Type: RM-240 (Nokia 6500s-1)
SW Version: V 10.00 06-03-09 RM-240 (c) Nokia
Imei plain: 35765901674649-9
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
PROCEDURE TO FOLLOW
1.Repair SD
2.SUPER SD Auth
3.PM Write
4.Repair SIMLOCK
Step by Step:
1. Repair SD.
Under IMEI & Security tab click IMEI Rebuild and click "Repair SD". Wait until mx-key finishes it's job..
Sample Log:
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 10.00 06-03-09 RM-240 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 4.906 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
After repairing SUPERDONGLE_KEY, SECURITY_TEST has been damaged.
see status:
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST failed!
proceed to next steps to restore SECURITY_TEST.
2. SUPER SD Auth.
Under PM tab click "SUPER SD Auth". Again wait for mx-key to finish..
Sample Log:
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
After the unit has been authorized, you can now write pm fields 1 and 309.. For my case, i use a complete pm file but chose to skip simlock area.
3. Write good pm file.
Still under PM tab..Locate "Load from file" then click it.. a folder will pop-up asking you to choose the pm file you would like to write.. pick the file then click "Open". Wait for mx-key to finish.
Sample Log:
Completed in 7.828 s
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 10 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 40, size 16 bytes written.
- Key: 41, size 182 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 36 bytes written.
- Key: 44, size 182 bytes written.
Section: 2
- Key: 0, size 448 bytes written.
Section: 4
- Key: 1, size 48 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
- Key: 28, size 2 bytes written.
Section: 8
- Key: 1, size 12 bytes written.
- Key: 7, size 8 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 2 bytes written.
- Key: 7, size 1 bytes written.
- Key: 8, size 1 bytes written.
- Key: 9, size 1 bytes written.
- Key: 10, size 1 bytes written.
- Key: 11, size 1 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 2 bytes written.
- Key: 15, size 2 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 2 bytes written.
- Key: 18, size 16 bytes written.
- Key: 19, size 32 bytes written.
- Key: 20, size 32 bytes written.
- Key: 21, size 2 bytes written.
- Key: 22, size 2 bytes written.
- Key: 23, size 2 bytes written.
- Key: 24, size 2 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 29, size 2 bytes written.
- Key: 30, size 2 bytes written.
- Key: 31, size 2 bytes written.
- Key: 32, size 2 bytes written.
- Key: 33, size 2 bytes written.
- Key: 34, size 2 bytes written.
- Key: 35, size 2 bytes written.
- Key: 36, size 2 bytes written.
- Key: 37, size 2 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 2 bytes written.
- Key: 44, size 2 bytes written.
- Key: 45, size 2 bytes written.
- Key: 46, size 2 bytes written.
- Key: 47, size 2 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 2 bytes written.
- Key: 51, size 2 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 2 bytes written.
- Key: 54, size 2 bytes written.
- Key: 55, size 2 bytes written.
- Key: 56, size 2 bytes written.
- Key: 57, size 2 bytes written.
- Key: 58, size 2 bytes written.
- Key: 59, size 2 bytes written.
- Key: 60, size 2 bytes written.
- Key: 61, size 2 bytes written.
- Key: 62, size 2 bytes written.
- Key: 63, size 2 bytes written.
- Key: 64, size 2 bytes written.
- Key: 65, size 4 bytes written.
- Key: 66, size 1 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 4 bytes written.
- Key: 69, size 4 bytes written.
- Key: 70, size 4 bytes written.
- Key: 71, size 16 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 13 bytes written.
Section: 31
- Key: 4, size 16 bytes written.
Section: 42
- Key: 0, size 2 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 40 bytes written.
- Key: 8, size 40 bytes written.
- Key: 9, size 40 bytes written.
- Key: 10, size 40 bytes written.
- Key: 11, size 40 bytes written.
- Key: 12, size 40 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
Section: 50
Section: 54
Section: 66
- Key: 0, size 2050 bytes written.
- Key: 1, size 240 bytes written.
- Key: 2, size 240 bytes written.
- Key: 3, size 1 bytes written.
- Key: 5, size 240 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 4 bytes written.
- Key: 8, size 4 bytes written.
- Key: 9, size 4 bytes written.
- Key: 10, size 240 bytes written.
- Key: 11, size 240 bytes written.
- Key: 16, size 4 bytes written.
- Key: 18, size 4 bytes written.
- Key: 20, size 4 bytes written.
- Key: 22, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 26, size 4 bytes written.
- Key: 28, size 4 bytes written.
- Key: 30, size 4 bytes written.
- Key: 32, size 4 bytes written.
- Key: 34, size 4 bytes written.
- Key: 57, size 8 bytes written.
- Key: 58, size 8 bytes written.
- Key: 59, size 8 bytes written.
- Key: 60, size 8 bytes written.
- Key: 61, size 8 bytes written.
- Key: 75, size 8 bytes written.
- Key: 76, size 8 bytes written.
- Key: 78, size 6144 bytes written.
- Key: 79, size 300 bytes written.
- Key: 80, size 60 bytes written.
- Key: 91, size 3 bytes written.
- Key: 92, size 3 bytes written.
- Key: 93, size 3 bytes written.
- Key: 94, size 3 bytes written.
- Key: 95, size 3 bytes written.
- Key: 96, size 3 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 4 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 4 bytes written.
- Key: 102, size 4 bytes written.
- Key: 103, size 6 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 116, size 120 bytes written.
- Key: 118, size 30 bytes written.
- Key: 119, size 1 bytes written.
- Key: 120, size 8 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 26, size 12 bytes written.
- 120 skipped
Section: 122
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 218
Section: 238
- Key: 1, size 1 bytes written.
Section: 309
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
Section: 322
- Key: 0, size 1 bytes written.
Section: 334
Section: 339
- Key: 0, size 511 bytes written.
- Key: 1, size 511 bytes written.
Section: 341
- Key: 4, size 4296 bytes written.
Section: 354
- Key: 0, size 3 bytes written.
Section: 356
- Key: 1, size 8 bytes written.
Section: 362
- Key: 1, size 120 bytes written.
Completed in 9.594 s
after pm write, check the status of the unit..
Product Code: 0543754
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST has been restored.. Proceed to next step to repair SIMLOCK.
4.Repair SIMLOCK.
Under "IMEI & SECURITY" click Simlock locate and click "Repair SIMLOCK" in Options menu. Also click "Make SIMLOCK RPL" then then click "Update SpLock". Wait for mx-key to finish.
Sample Log:
Calculating SIMLOCK using security server ...
Completed in 4.672 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 357659016746499
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
After all procedure's are done, scan the unit again to check it's status..
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Unit successfully repaired.. thanks to Mx-key team..
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
Unlock Nokia 6120 rerednaw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-28-1999 11:45
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.22720 seconds with 9 queries
